 Post subject: How can I repair bad sectors using mhdd?
PostPosted: February 24th, 2005, 8:59
Hi,everybody. I'm a newer to mhdd. Now I want to use mhdd4.0 to repaire a Seagate 40GB harddisk which contains bad sectors. Who can tell me the procedure step by step? Thanks a lot.
PostPosted: February 24th, 2005, 10:27
1. Erase
2. Scan+erasewaits
3. Scan+Remap.
PostPosted: February 28th, 2005, 22:06
Dmitry:
Is persistent remap done here? One that permanently hides the bad sectors even if partitioned and formatted many times?
PostPosted: February 28th, 2005, 22:43
I can't understand the question.
PostPosted: February 28th, 2005, 22:50
I was asking that question because I have once used ERASE WAITS but when I repartitioned and reformatted the HDD, the WAITS reappeared.
PostPosted: March 1st, 2005, 11:00
That depends on many things :-), maybe you have broken HDD or power supply is "not good".
PostPosted: March 1st, 2005, 11:21
Thank you for your answer, Master Dmitry.
But I used PC3K to diagnose the firmware zone, controller, etc. Everything's fine. So there are no maybe's for this drive.
PostPosted: March 1st, 2005, 12:17
There are many other very interesting things in the drive like platters, motor, heads...
написано 1/3/2005, 11:19:
So, it is not like a pregnancy (you are pregnant or you are not pregnant :)).
Users browsing this forum: Doomer, Google [Bot] and 27 guests
