 Post subject: HELP: NEED MOD 47 FROM 40 - TrailXLB2 (
PostPosted: October 28th, 2020, 8:46
HDD : WDC WD10EZEX-60WN4A1
F/W : 03.01A03 05.6TH
FMLY : TrailXLB2
TOOLS: MRT 2.1.4.1 AND WDMARVEL (LICENSE) NOT PLUS (THERE OPTION IN PLUS VERSION TO GET 47 FROM 40)
Patient HDD spindown with original rom but spin with donor rom.
modified donor rom with patient 47 then hdd spin down
with donor rom can read some modules (head 0) ok others with dam_err and ecu_unsafe_err
attached donor and patient rom with modules 47 and 40
PATIENT.rar [214.97 KiB]
Downloaded 722 times
DONOR.rar [214.96 KiB]
Downloaded 723 times
 Post subject: Re: HELP: NEED MOD 47 FROM 40 - TrailXLB2 (
PostPosted: October 28th, 2020, 12:22
if patient spin down i think you have head issue. Do you have a donor ? match module 47 first
PostPosted: October 28th, 2020, 15:09
I don't understand why you would want to regenerate module 0x47 if you already have the original copy. :-?
PostPosted: October 28th, 2020, 22:58
i suspect patient 47 may be corrupted since with patient rom hdd clicks and spin down but in donor rom no spin down
PostPosted: October 29th, 2020, 6:52
With Donor ROM i can access user area.
but sequence of some thousands sector read and large amount of sectors unreadable then some green and then large section err and so on...
then why it is [b]spin down only with PATIENT ROM[/b]?
PostPosted: October 29th, 2020, 12:06
Swap head from donor to patient and copy module 47 from donot to patient .
PostPosted: October 29th, 2020, 13:28
Well,
Mod 47 Has Only Heads Info ,No Media info ? ,What do you think ?
PostPosted: October 29th, 2020, 14:04
It would appear that module 0x47 is native. I haven't examined the whole module, but here you can see the same block of data in mods 40 and 47.
From patient mod 0x47 ...
Offset(h) 00   02   04   06   08   0A   0C   0E
00000030  5657 7B03 8386 B3B3 9584 8482 8255 8000
00000040  BE73 FF77 FC7F 9A52 B672 0402 0303 3F00
00000050  3C00 3536 3333 312E 2E2D FD11 01FF 1001
00000060  F2CE 0A00 03EF FE01 0000 EC10 0000 0000
00000070  5657 0901 0000 C609 0000 3C00 8080 062B
00000080  0823 362C
From patient mod 0x40 ...
00005570                                5657 7B03
00005580  8386 B3B3 9584 8482 8255 8000 BE73 FF77
00005590  FC7F 9A52 B672 0402 0303 3F00 3C00 3536
000055A0  3333 312E 2E2D FD11 01FF 1001 F2CE 0A00
000055B0  03EF FE01 0000 EC10 0000 0000 5657 0901
000055C0  0000 C609 0000 3C00 8080 062B 0823 362C
Users browsing this forum: No registered users and 264 guests
