 Post subject: Seagate EXOS X16 ST16000NM001G
PostPosted: October 27th, 2020, 23:43
this is a fairly new drive 16TB
Drive idents to PC3K but does not initialize to the file system
this is the terminal output
thinking firmware issues or media cache.
anyone have ideas for this?
Boot0x0100MAX0122SN02Motor startedHeads loadedPass w/o polarity switch
Trans
Rst0x0100MAX0122SN02
(P)SATAReset
NVCScramSavedHBSize:020A
LD:MD_Alloc:00000090HB_Alloc:0000FlashRestorePowerDevReg7E:0001 PowerDevReg7D:0000MD_Saved:00000090HB_Saved:00000000MD_CRC:CFB7
PP:MD_Alloc:0000F000HB_Alloc:0000FlashRestore
PVTSize:0010CE8C CompSize:00002204 DeCompSize:0010CE8CMD_Saved:00002204HB_Saved:00000000MD_CRC:A025
TW:MD_Alloc:00000400HB_Alloc:002EFlashRestoreMD_Saved:00000160HB_Saved:00000000MD_CRC:2493
WCD:MD_Alloc:00040000HB_Alloc:1293FlashRestoreMD_Saved:000009BBHB_Saved:00000000MD_CRC:15D6
GC:MD_Alloc:00005000HB_Alloc:0000FlashRestoreMD_Saved:00004348HB_Saved:00000000MD_CRC:7108
DSP00CA
2Sync:0 4
ASCII Diag mode
LPower=
HPower
TCC:0014 Humidity:0.0% Pressure:683 mBars PartialPressure:684.32 mBars EMCDataErr:00000000 Req=0038 Status=0001ACTIVE
F3 T>
Diagnostic Port Locked
Trans
(P)SATAReset
LD:MD_Alloc:00000090HB_Alloc:0000FlashRestorePowerDevReg7E:3801 PowerDevReg7D:0000MD_Saved:00000090HB_Saved:00000000MD_CRC:DF01
GC:MD_Alloc:00005000HB_Alloc:0000FlashRestoreMD_Saved:00004348HB_Saved:00000000MD_CRC:299B
DSP00CB
2Sync:0 4
ABORT!
OpCode=00000024
SenseCode=0B090400
ReadyStatusFlags=0102A1E0
ABORT!
OpCode=00000024
SenseCode=0B090400
ABORT!
OpCode=00000024
SenseCode=0B090400
ABORT!
OpCode=00000024
SenseCode=0B090400
#-CF1
 Post subject: Re: Seagate EXOS X16 ST16000NM001G
PostPosted: October 28th, 2020, 5:07
i can probably unlock it and deal with the problem. I expect some R & D to be required though.
PostPosted: October 28th, 2020, 12:45
Hello.
Check if a ata-password has been set? ))
Users browsing this forum: Bing [Bot] and 286 guests
