Hard Drive Burned
January 7th, 2024, 9:30
Hello Everyone! Yesterday, I pretty much built another pc and I had a Toshiba 2TB hard drive that I used as a backup & storage for pictures and family documents. Long story short, with the new pc, the PSU wont start unless I removed the PCIE to SATA cable feeding HDD, it was working right on my other pc so I took it back to it and it didnt read it as well... I tried other PCIE to SATA cables on the modular PSU (Corsair HX1000) I one of these caused the HDD to burn the SATA connector and even the SATA cable to the motherboard melted... I didnt feel the HDD move the internals at all.
Any advice would be appreciated, from what I have read, I could find a donor board with identical chips and swap the eprom, but since this was a case that burned the connector, I am concerned about internals such as the motor causing issues again.
Re: Hard Drive Burned
January 7th, 2024, 20:20
The motor controller IC (0A73080) has a burn mark.
The 0.47 ohm resistor (R470) near the HDA connector also appears to be burnt. Can you measure its resistance? This resistor is in series with the supply to the preamp.
January 7th, 2024, 20:42
fzabkar wrote:The motor controller IC (0A73080) has a burn mark.
It is measuring 0.5 ohms after measuring it multiple times. I agree, the motor controller had something so I guess its one of the first things to go out?
thanks for replying!
January 7th, 2024, 20:55
So I found a board with the same board number, VCM Controller and MCU but different memory brand, is that ok? From what I have read I have to swap the EPROM to attempt to make the drive work again.
Is this the eprom? Anyone know what could have cause this?
January 7th, 2024, 21:43
Firstly, stop experimenting with modular PSU cables. Their pinouts are not standardised. What has happened is that you have applied 12V to the drive's 5V input. This has destroyed the motor controller IC and potentially the preamp on the headstack inside the drive.
http://www.hddoracle.com/viewtopic.php?f=56&t=2545
The chip you have identified is a serial flash memory, aka "ROM". It does need to be transferred to a donor PCB.
Measure the resistance between these voltage test points and ground (eg a screw hole):
https://www.hddoracle.com/download/file.php?id=10175&mode=view
This will tell us if the preamp is shorted.
Also check the TVS diodes and fuses:
https://www.hddoracle.com/viewtopic.php?f=100&t=86
January 7th, 2024, 22:54
fzabkar wrote:Firstly, stop experimenting with modular PSU cables. Their pinouts are not standardised. What has happened is that you have applied 12V to the drive's 5V input. This has destroyed the motor controller IC and potentially the preamp on the headstack inside the drive.
got it, i guess it is time to buy a usb to sata cable or is it fine to use a modular cable that avoids the 12v?
I measured the resistance between the voltage test points and the multimeter read resistance on all locations NONE were close to 0.
As for the TVS diodes, I also got resistance on both and measuring in both locations. One had 0.72k / 29.5k ohm depending on the direction and the other one 96k / 82k ohm.
Thanks for your help.
January 7th, 2024, 23:21
The sata cable to the motherboard also got really hoy and melted. I forgot to mention that I plugged in the HDD while the psu was on (stupid move).
January 8th, 2024, 0:53
That means that you had power on the ground wires.
January 8th, 2024, 11:59
I should have highlighted this post:
https://www.hddoracle.com/viewtopic.php?p=23821#p23821
It's not sufficient to just test the PCB on its own when checking the preamp for shorts.
January 8th, 2024, 12:44
fzabkar wrote:I should have highlighted this post:
gotcha, that board is different than mine (0A90380) but found the same board with testing points on this site:
+5 to GND off - 11.12kohm
-5 to GND off - 0.352kohm
-5 to +5 off - 9.74kohm
+5 to GND ON - 7.55kohm
-5 to GND ON - 5.62kohm
-5 to +5 ON - 16.15k ohm
January 8th, 2024, 13:13
I did test the continuity for the fuses on the board, according to the post here: https://forum.hddguru.com/viewtopic.php?t=36362 and found that one of them is shut.
January 8th, 2024, 13:18
These results seem to be reversed.
January 8th, 2024, 13:47
allright, I changed the batteries on my multimeter redid all measurements:
OFF = board is off HDD
+5 to GND off - 8.48kohm
-5 to GND off - 5.51kohm
ON = board is attached to HDD (but not powered on)
+5 to GND ON - 11.13kohm
-5 to GND ON - 0.340kohm
-5 to +5 ON - 8.11k ohm
January 8th, 2024, 14:07
I get 5.5k ohm from GND to -5 ON (reversed) instead of 0.34kohm
January 8th, 2024, 14:10
Just try a replacement PCB and hope for the best. Good luck.
January 8th, 2024, 14:11
fzabkar wrote:Just try a replacement PCB and hope for the best. Good luck.
thanks for your help, does the preamp numbers look ok?
January 8th, 2024, 14:41
The readings seem to compare well with other PCBs (apart from 340 ohms).
January 12th, 2024, 18:10
Got the donor board, but the MCU looks different even though both say 6045, is this a concern? I want to make sure before I swap the EPROM. VCM has the same number
OLD MCU:
NEW MCU:
OLD VCM:
NEW VCM:
Board:
January 12th, 2024, 18:36
Markings beginning with 0A or 0B are HGST part numbers. Therefore, the VCM part numbers are 0A73080.
The SDRAMs have different capacities.
K4T56163QN = Samsung 256Mbit (16M x 16) N-die DDR2 SDRAM
https://datasheet.ciiva.com/26786/k4t56163qn-hce7-26786865.pdf
M14D5121632A = ESMT 8M x 16 Bit x 4 Banks DDR II SDRAM (512Mbit)
https://www.esmt.com.tw/upload/pdf/ESMT/datasheets/M14D5121632A(2A).pdf
I don't know the matching rules for this drive, but this site refers to a sticker on the back of the PCB:
https://www.hdd-parts.com/14090304.html
January 12th, 2024, 18:57
thanks for replying, thats not the best news for me, maybe i should have done better homework.
Would it risk the data of i tried to use this board?
