 Post subject: Toshiba MQ01UBD100 PCB swap to MQ01ABD100
PostPosted: October 3rd, 2020, 0:53
Hi I have a Toshiba MQ01UBD100 which stopped being recognised by Windows, so I tried moving the BIOS chip over to a MQ01ABD100 PCB (SATA version of the board) but it clicks when starting up, and eventually gives me a user password prompt. The original drive was not password protected. Are there any chips that need to be moved across to the SATA PCB?
Video of the clicking sound: https://streamable.com/2xev3n
 Post subject: Re: Toshiba MQ01UBD100 PCB swap to MQ01ABD100
PostPosted: October 3rd, 2020, 5:57
Post pics of the two PCBS, clear enough so we can see the numbers on the chips.
I suspect the pcb's aren't compatible.
PostPosted: October 3rd, 2020, 15:19
"A" PCB (SATA, G003235C):
https://sep.yimg.com/ay/yhst-14437584971410/91707118-6.gif
"U" PCB (USB):
https://pbs.twimg.com/media/B7X3CV3CcAECJsB?format=jpg&name=large
MCU = Marvell 88i9317-RA12
Motor controller = TI TLS2602 / TLS2605 <-- ???
SDRAM = Zentel A3S64D40GTP-50
PostPosted: October 4th, 2020, 14:36
Correct!
If the PCB has a different motor controller it WILL click.
PostPosted: October 9th, 2020, 23:41
pcimage wrote:
Correct!
So it should just be a case of swapping the motor controller over then?
PostPosted: October 11th, 2020, 3:20
decayed.cell wrote:
pcimage wrote:
Correct!
Of course not!
PostPosted: October 11th, 2020, 16:13
I believe that G003138A should be a match:
https://www.hdd-parts.com/14103577.html
PostPosted: October 11th, 2020, 20:29
Hmm that comes from the 750GB drive, so I thought the 1TB board would work.
The original USB board has a TLS2605 controller, which is the same on the SATA board which I swapped the BIOS chip to - G003235C
remove duplicates from string
Furthermore its reported on Data Medics that a G3448A to G003235C swap should work.
I should probably also add that I bought a second G3448A board, swapped the BIOS on to that as well and the drive just did nothing. I verified that the BIOS chip was written correctly by taking the chip off the board and reading it back out with my TL866
PostPosted: October 15th, 2020, 5:56
hi it worked I managed to recover this toshiba
PostPosted: November 15th, 2020, 9:41
What swap did you do exactly?
Users browsing this forum: Google [Bot], we3fan and 300 guests
