 Post subject: Is there a trick to removing WD Charger heads?
PostPosted: December 18th, 2020, 8:32
I might be missing something but I can not see a screw holding these heads in. I can not seem to pull the heads up as one does when there is no screw on the bottom of the drive. How do they come out? Is there some sort of allen screw hidden at the bottom of the central shaft?
Gordon
 Post subject: Re: Is there a trick to removing WD Charger heads?
PostPosted: December 18th, 2020, 9:13
you just need to pull it off the shaft.
PostPosted: December 18th, 2020, 10:28
I always use my two hands and a tweezers.
PostPosted: December 18th, 2020, 15:05
It can be a tight fit sometimes, and you have to jiggle it a little :-)
Users browsing this forum: Google [Bot], Hardcore Games, Majestic-12 [Bot] and 59 guests
