 Post subject: Toshiba MQ04UBB400 (4TB USB 3) not detected but spins
PostPosted: December 3rd, 2020, 8:29
Hi everybody,
so this Toshiba MQ04UBB400 USB3 drive spins fine but is not recognized. I have converted it to SATA by soldering wires (and desoldering capasitors). The situation stays as same, spins fine and that's all.
I have measured the VLI with these results:
-Vcore +1,2V
-Vio +3,3V
- +5V
Resistance between core is 5,2 kOhms.
Any hints how to proceed?
 Post subject: Re: Toshiba MQ04UBB400 (4TB USB 3) not detected but spins
PostPosted: December 3rd, 2020, 12:49
Not recognized in wich utility?
PostPosted: December 3rd, 2020, 13:22
Neither PC3K nor any computer does recognize this one.
PostPosted: December 3rd, 2020, 13:28
Try compatible SATA pcb with different matching families. If not able to ID the drive, better check NVRAM data for further clarification.
PostPosted: December 3rd, 2020, 13:38
Ok, thank you. I'll have to try it as next step.
PostPosted: December 3rd, 2020, 15:02
What is your USB PCB number?
PostPosted: December 3rd, 2020, 15:47
Sorry, this has dropped out of the original posting.
PostPosted: December 3rd, 2020, 15:52
But what is the number on the back of the board.
PostPosted: December 3rd, 2020, 15:57
There is only this little stiker with QR code and marking 01C0. Reading the QR code I get EF602A49H A5A900034010 if this is even valid infomation.
PostPosted: December 3rd, 2020, 16:02
Is there not a number in gold under the spindle hole like G4330A.
PostPosted: December 3rd, 2020, 16:06
My apologies. :oops:
Of course the is: G0034A
PostPosted: December 3rd, 2020, 16:11
SATA PCB G4311A should be a good match. At least you can rule out the PCB.
PostPosted: December 3rd, 2020, 16:16
Great! Thank you a lot! :good:
PostPosted: December 4th, 2020, 10:03
Considering it's USB I would use hddsuperclone on linux.
PostPosted: December 5th, 2020, 0:52
Ok, thank you. I will familiarize me to this option.
Users browsing this forum: No registered users and 58 guests
