 Post subject: WD30EFRX Not sure if bad, seeing conflicting information
PostPosted: December 9th, 2020, 22:48
I've got a WD30EFRX that was in a Synology NAS. I noticed that on one of the periodic Extended SMART tests, that it was hung at 90%. Apparently, this is a somewhat common issue with Synology and WD drives. I wasn't aware of this right when it happened, and I immediately ordered two new replacement drives (my other WD30EFRX appears to be perfectly fine).
I read in a thread about the issue with Synology, that if you take the drive out, run the extended test via the WD DataLifeGuard tools, the pop it back in the Synology, that it will test and run fine. I did that, and it failed WD DLG extended. I popped it back into the Synology, where it passed both the quick and extended tests.
Since I'd already purchased new drives, I decided to pull the WD, and if they ended up being fine, upgrading the 1TB drives in my Synology at a backup location. So, I set out to test this drive. The SMART data itself shows no reallocated sectors, nor any uncorrectable. I've seen a pending count of 1 come and go during all my testing.
I ran badblocks and got this output:
[liveuser@localhost-live mapper]$ sudo badblocks -b 4096 -wsv /dev/sdc
Checking for bad blocks in read-write mode
From block 0 to 732566645
Testing with pattern 0xaa: done
Reading and comparing: 11128660done, 8:29:43 elapsed. (0/0/0 errors)
12782558done, 8:31:00 elapsed. (1/0/0 errors)
done
Testing with pattern 0x55: done
Reading and comparing: 12782184done, 25:00:18 elapsed. (2/0/0 errors)
done
Testing with pattern 0xff: done
Reading and comparing: 12782613done, 41:29:48 elapsed. (3/0/0 errors)
done
Testing with pattern 0x00: done
Reading and comparing: 9239173 done, 57:56:42 elapsed. (4/0/0 errors)
done
Pass completed, 5 bad blocks found. (5/0/0 errors)
Here is the output of smartctl:
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.8.15-301.fc33.x86_64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4N5UJXSP8
LU WWN Device Id: 5 0014ee 262c9fd8f
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is:    Wed Dec  9 11:00:18 2020 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)   Offline data collection activity
               was never started.
               Auto Offline Data Collection: Disabled.
Self-test execution status:      ( 121)   The previous self-test completed having
               the read element of the test failed.
Total time to complete Offline
data collection:       (39600) seconds.
capabilities:           (0x7b) SMART execute Offline immediate.
               Auto Offline data collection on/off support.
               Suspend Offline collection upon new
               command.
               Offline surface scan supported.
               Self-test supported.
               Conveyance Self-test supported.
               Selective Self-test supported.
SMART capabilities:            (0x0003)   Saves SMART data before entering
               power-saving mode.
               Supports SMART auto save timer.
Error logging capability:        (0x01)   Error logging supported.
               General Purpose Logging supported.
Short self-test routine
recommended polling time:     (   2) minutes.
Extended self-test routine
recommended polling time:     ( 398) minutes.
Conveyance self-test routine
recommended polling time:     (   5) minutes.
SCT capabilities:           (0x703d)   SCT Status supported.
               SCT Error Recovery Control supported.
               SCT Feature Control supported.
               SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       417
  3 Spin_Up_Time            0x0027   210   175   021    Pre-fail  Always       -       4500
  4 Start_Stop_Count        0x0032   090   090   000    Old_age   Always       -       10803
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   055   055   000    Old_age   Always       -       32910
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   095   095   000    Old_age   Always       -       5010
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       33
193 Load_Cycle_Count        0x0032   197   197   000    Old_age   Always       -       10835
194 Temperature_Celsius     0x0022   121   106   000    Old_age   Always       -       29
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       1
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       19
SMART Error Log Version: 1
ATA Error Count: 6 (device log contains only the most recent five errors)
   CR = Command Register [HEX]
   FR = Features Register [HEX]
   SC = Sector Count Register [HEX]
   SN = Sector Number Register [HEX]
   CL = Cylinder Low Register [HEX]
   CH = Cylinder High Register [HEX]
   DH = Device/Head Register [HEX]
   DC = Device Command Register [HEX]
   ER = Error register [HEX]
   ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 6 occurred at disk power-on lifetime: 32901 hours (1370 days + 21 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 08 28 d4 67 e4  Error: UNC 8 sectors at LBA = 0x0467d428 = 73913384
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  c8 00 08 28 d4 67 e4 00   2d+15:08:44.982  READ DMA
  c8 00 08 20 d4 67 e4 00   2d+15:08:44.982  READ DMA
  c8 00 08 18 d4 67 e4 00   2d+15:08:44.982  READ DMA
  c8 00 08 10 d4 67 e4 00   2d+15:08:44.981  READ DMA
  c8 00 08 08 d4 67 e4 00   2d+15:08:44.981  READ DMA
Error 5 occurred at disk power-on lifetime: 32884 hours (1370 days + 4 hours)
  40 51 08 a8 60 18 e6  Error: UNC 8 sectors at LBA = 0x061860a8 = 102260904
  c8 00 08 a8 60 18 e6 00   1d+22:42:48.525  READ DMA
  c8 00 08 a0 60 18 e6 00   1d+22:42:48.525  READ DMA
  c8 00 08 98 60 18 e6 00   1d+22:42:48.525  READ DMA
  c8 00 08 90 60 18 e6 00   1d+22:42:48.525  READ DMA
  c8 00 08 88 60 18 e6 00   1d+22:42:48.524  READ DMA
Error 4 occurred at disk power-on lifetime: 32868 hours (1369 days + 12 hours)
  40 51 08 40 53 18 e6  Error: UNC 8 sectors at LBA = 0x06185340 = 102257472
  c8 00 08 40 53 18 e6 00   1d+06:14:15.198  READ DMA
  c8 00 08 38 53 18 e6 00   1d+06:14:15.198  READ DMA
  c8 00 08 30 53 18 e6 00   1d+06:14:15.198  READ DMA
  c8 00 08 28 53 18 e6 00   1d+06:14:15.198  READ DMA
  c8 00 08 20 53 18 e6 00   1d+06:14:15.198  READ DMA
Error 3 occurred at disk power-on lifetime: 32851 hours (1368 days + 19 hours)
  40 51 08 f0 5e 18 e6  Error: UNC 8 sectors at LBA = 0x06185ef0 = 102260464
  c8 00 08 f0 5e 18 e6 00      13:45:55.098  READ DMA
  c8 00 08 e8 5e 18 e6 00      13:45:55.098  READ DMA
  c8 00 08 e0 5e 18 e6 00      13:45:55.095  READ DMA
  c8 00 08 d8 5e 18 e6 00      13:45:55.095  READ DMA
  c8 00 08 d0 5e 18 e6 00      13:45:55.095  READ DMA
Error 2 occurred at disk power-on lifetime: 32851 hours (1368 days + 19 hours)
  40 51 08 a0 7a 4e e5  Error: UNC 8 sectors at LBA = 0x054e7aa0 = 89029280
  c8 00 08 a0 7a 4e e5 00      13:44:37.792  READ DMA
  c8 00 08 98 7a 4e e5 00      13:44:37.792  READ DMA
  c8 00 08 90 7a 4e e5 00      13:44:37.792  READ DMA
  c8 00 08 88 7a 4e e5 00      13:44:37.792  READ DMA
  c8 00 08 80 7a 4e e5 00      13:44:37.792  READ DMA
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed: read failure       90%     32910         73913384
# 2  Short offline       Completed: read failure       90%     32910         73913384
# 3  Short offline       Completed: read failure       90%     32910         73913384
# 4  Short offline       Completed: read failure       90%     32910         73913384
# 5  Extended offline    Completed: read failure       90%     32837         73912826
# 6  Short offline       Completed: read failure       90%     32837         73912824
# 7  Short offline       Completed: read failure       20%     32815         15223248
# 8  Extended offline    Completed without error       00%     32702         -
# 9  Short offline       Completed without error       00%     32693         -
#10  Short offline       Completed: read failure       20%     32651         15226416
#11  Short offline       Completed: read failure       20%     32651         15226416
#12  Extended offline    Aborted by host               10%     32633         -
#13  Short offline       Completed without error       00%     32457         -
#14  Extended offline    Aborted by host               10%     32457         -
#15  Short offline       Completed without error       00%     29778         -
#16  Short offline       Completed without error       00%     28315         -
#17  Short offline       Completed without error       00%     26854         -
#18  Short offline       Completed without error       00%     25535         -
#19  Short offline       Completed without error       00%     24792         -
#20  Short offline       Completed without error       00%     23336         -
#21  Short offline       Completed without error       00%     21874         -
2 of 9 failed self-tests are outdated by newer successful extended offline self-test # 8
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Now, after this, I decided to run it through WD DLG again. This time, the quick test failed, but the extended said it found some bad sectors that were repairable. So, I clicked repair, and it said it repaired them and marked the extended test as passed. A follow-up quick test still fails. SMART data at this point still shows no reallocated sectors, no pending sectors, and no offline uncorrectable.
Output of WD DLG:
Test Option:      QUICK TEST
Model Number:      WDC WD30EFRX-68EUZN0
Unit Serial Number:   WD-WCC4N5UJXSP8
Firmware Number:   82.00A82
Capacity:      3000.59 GB
SMART Status:      PASS
Test Result:      FAIL
Test Error Code:   "06-Quick Test on drive 3 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 3!"
Test Time:      12/9/2020 11:13
Test Option:      EXTENDED TEST
SMART Status:      PASS
Test Result:      PASS
Test Time:      12/9/2020 20:46
SMART Status:      PASS
Test Result:      FAIL
Test Error Code:   "06-Quick Test on drive 3 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 102 (Unknown Test) SMART self-test did not complete on drive 3!"
Test Time:      12/9/2020 20:48
So, at this point, I'm not sure what to make of this.
 Post subject: Re: WD30EFRX Not sure if bad, seeing conflicting information
PostPosted: December 11th, 2020, 15:01
I wouldn't trust that drive. It has non-zero error rates and 1 pending sector.
Users browsing this forum: Google [Bot] and 57 guests
