 Post subject: WD10PURX-64E5EY0 head test.
PostPosted: December 15th, 2020, 8:50
I am using WDmarvel for this test and having problems. Anyone care to comment?
Why would head test lock up the program?
12/14/2020 6:17:13 PM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: WD-WCC4J7KS7CV9, LBA 1953525168 - 1000Gb
12/14/2020 6:17:28 PM: P-list read successfully
WD Marvel locks up here, can not do anything but kill it in task manager and restart.
12/14/2020 7:34:21 PM: Controllers search, found 2 devices
12/14/2020 7:34:21 PM: Device selected 20B0h 20CAh Master
12/14/2020 7:34:25 PM: Connecting to server #1...
12/14/2020 7:34:27 PM: Connection with the server established, the user - sarnett@info-ed.com, license type - Standard
12/14/2020 7:34:40 PM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: WD-WCC4J7KS7CV9, LBA 1953525168 - 1000Gb
12/14/2020 7:34:54 PM: Head map successfully changed
Changed head map to just 0 in ID0A, power off.
12/14/2020 7:50:56 PM: Controllers search, found 2 devices
12/14/2020 7:50:56 PM: Device selected 20B0h 20CAh Master
12/14/2020 7:51:00 PM: Connecting to server #1...
12/14/2020 7:51:02 PM: Connection with the server established, the user - sarnett@info-ed.com, license type - Standard
12/14/2020 7:51:22 PM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: , LBA 0 - 0Gb
12/14/2020 7:51:23 PM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: , LBA 0 - 0Gb
12/14/2020 7:51:53 PM: Error reading zone table for head 0.
12/14/2020 7:52:02 PM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: , LBA 0 - 0Gb
12/14/2020 7:52:20 PM: Error reading zone table for head 0.
I get this error above.
12/14/2020 7:52:40 PM: Head map successfully changed
12/14/2020 8:03:20 PM: Controllers search, found 2 devices
12/14/2020 8:03:20 PM: Device selected 20B0h 20CAh Master
12/14/2020 8:03:24 PM: Connecting to server #1...
12/14/2020 8:03:26 PM: Connection with the server established, the user - sarnett@info-ed.com, license type - Standard
12/14/2020 8:03:46 PM: Drive: , family: TrailXLB (Royl), FW: 01.5RR, SN: , LBA 0 - 0Gb
12/14/2020 8:03:49 PM: The drive did not raise the flag DRQ
12/14/2020 8:03:50 PM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: , LBA 0 - 0Gb
12/14/2020 8:04:08 PM: Error reading zone table for head 0.
Changed head map to just 1 in ID0A, power off and retry with this error above.
Are both heads dead? Any suggestions?
 Post subject: Re: WD10PURX-64E5EY0 head test.
PostPosted: December 15th, 2020, 14:23
This is a bug in the program. It's explained on the wdmarvel forum how to solve it. You should not change the head map!
PostPosted: December 15th, 2020, 20:54
I searched the forum but I do not see what you speak of. Can you kindly tell me what to search for?
PostPosted: December 16th, 2020, 4:29
https://wdmarvel.com/forum/ru/viewtopic ... t&start=20
PostPosted: December 16th, 2020, 7:50
Thanks BGman! That fixed it! And as I expected:
12/16/2020 5:34:09 AM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: WD-WCC4J7KS7CV9, LBA 1953525168 - 1000Gb
12/16/2020 5:34:23 AM: P-list read successfully
12/16/2020 5:35:24 AM: Write tracks on head 0 - Ok
12/16/2020 5:39:15 AM: Read tracks on head 0 - errors: 50, success: 0
12/16/2020 5:39:45 AM: Write tracks on head 1 - Ok
12/16/2020 5:39:49 AM: Read tracks on head 1 - Ok
Now should I disable head 0?
PostPosted: December 17th, 2020, 3:58
Yes. If you know how....
Have you done it before?
PostPosted: December 17th, 2020, 7:45
Never mind, looks as though I have more problems:
12/16/2020 11:34:03 AM: Controllers search, found 2 devices
12/16/2020 11:34:04 AM: Device selected 20B0h 20CAh Master
12/16/2020 11:34:08 AM: Connecting to server #1...
12/16/2020 11:34:11 AM: Connection with the server established, the user - , license type - Standard
12/16/2020 11:34:30 AM: Drive: WDC WD10PURX-64E5EY0, family: TrailXLB (Royl), FW: 01.5RR, SN: WD-WCC4J7KS7CV9, LBA 1953525168 - 1000Gb
12/16/2020 11:37:10 AM: P-list read successfully
12/16/2020 11:38:57 AM: G-list read successfully
12/16/2020 11:39:27 AM: New format type drive detected
12/16/2020 11:41:17 AM: P-list read successfully
12/16/2020 11:43:43 AM: Write tracks on head 1 zone 1 - Ok
12/16/2020 11:51:54 AM: Read tracks on head 1 zone 1 - errors: 100, success: 0
12/16/2020 12:00:20 PM: Controllers search, found 2 devices
12/16/2020 12:00:20 PM: Device selected 20B0h 20CAh Master
12/16/2020 12:00:24 PM: Connecting to server #1...
12/16/2020 12:00:26 PM: Connection with the server established, the user - , license type - Standard
12/16/2020 12:00:52 PM: P-list read successfully
12/16/2020 12:03:01 PM: Write tracks on head 1 zone 1 - Ok
12/16/2020 12:11:03 PM: Read tracks on head 1 zone 1 - errors: 100, success: 0
12/16/2020 12:12:56 PM: Write tracks on head 1 zone 2 - Ok
12/16/2020 12:21:10 PM: Read tracks on head 1 zone 2 - errors: 100, success: 0
12/16/2020 12:23:04 PM: Write tracks on head 1 zone 3 - Ok
12/16/2020 12:31:19 PM: Read tracks on head 1 zone 3 - errors: 100, success: 0
12/16/2020 12:33:16 PM: Write tracks on head 1 zone 4 - Ok
12/16/2020 12:41:32 PM: Read tracks on head 1 zone 4 - errors: 100, success: 0
12/16/2020 12:43:26 PM: Write tracks on head 1 zone 5 - Ok
12/16/2020 12:51:34 PM: Read tracks on head 1 zone 5 - errors: 100, success: 0
12/16/2020 12:53:27 PM: Write tracks on head 1 zone 6 - Ok
12/16/2020 1:01:46 PM: Read tracks on head 1 zone 6 - errors: 100, success: 0
12/16/2020 1:03:38 PM: Write tracks on head 1 zone 7 - Ok
12/16/2020 1:11:53 PM: Read tracks on head 1 zone 7 - errors: 100, success: 0
12/16/2020 1:13:43 PM: Write tracks on head 1 zone 8 - Ok
12/16/2020 1:21:59 PM: Read tracks on head 1 zone 8 - errors: 100, success: 0
12/16/2020 1:23:48 PM: Write tracks on head 1 zone 9 - Ok
12/16/2020 1:32:15 PM: Read tracks on head 1 zone 9 - errors: 100, success: 0
12/16/2020 1:34:04 PM: Write tracks on head 1 zone 10 - Ok
12/16/2020 1:42:19 PM: Read tracks on head 1 zone 10 - errors: 100, success: 0
12/16/2020 1:44:08 PM: Write tracks on head 1 zone 11 - Ok
12/16/2020 1:52:25 PM: Read tracks on head 1 zone 11 - errors: 100, success: 0
12/16/2020 1:54:12 PM: Write tracks on head 1 zone 12 - Ok
12/16/2020 2:02:22 PM: Read tracks on head 1 zone 12 - errors: 100, success: 0
12/16/2020 2:04:08 PM: Write tracks on head 1 zone 13 - Ok
12/16/2020 2:12:21 PM: Read tracks on head 1 zone 13 - errors: 100, success: 0
12/16/2020 2:14:05 PM: Write tracks on head 1 zone 14 - Ok
12/16/2020 2:22:22 PM: Read tracks on head 1 zone 14 - errors: 100, success: 0
12/16/2020 2:24:08 PM: Write tracks on head 1 zone 15 - Ok
12/16/2020 2:32:24 PM: Read tracks on head 1 zone 15 - errors: 100, success: 0
12/16/2020 2:34:07 PM: Write tracks on head 1 zone 16 - Ok
12/16/2020 2:42:37 PM: Read tracks on head 1 zone 16 - errors: 100, success: 0
12/16/2020 2:44:18 PM: Write tracks on head 1 zone 17 - Ok
12/16/2020 2:52:43 PM: Read tracks on head 1 zone 17 - errors: 100, success: 0
12/16/2020 2:54:25 PM: Write tracks on head 1 zone 18 - Ok
12/16/2020 3:02:54 PM: Read tracks on head 1 zone 18 - errors: 100, success: 0
12/16/2020 3:04:35 PM: Write tracks on head 1 zone 19 - Ok
12/16/2020 3:13:02 PM: Read tracks on head 1 zone 19 - errors: 100, success: 0
12/16/2020 3:15:01 PM: Write tracks on head 1 zone 20 - Ok
12/16/2020 3:23:38 PM: Read tracks on head 1 zone 20 - errors: 100, success: 0
12/16/2020 3:25:16 PM: Write tracks on head 1 zone 21 - Ok
12/16/2020 3:33:41 PM: Read tracks on head 1 zone 21 - errors: 100, success: 0
12/16/2020 3:35:18 PM: Write tracks on head 1 zone 22 - Ok
12/16/2020 3:43:46 PM: Read tracks on head 1 zone 22 - errors: 100, success: 0
12/16/2020 3:45:22 PM: Write tracks on head 1 zone 23 - Ok
12/16/2020 3:54:00 PM: Read tracks on head 1 zone 23 - errors: 100, success: 0
12/16/2020 3:55:38 PM: Write tracks on head 1 zone 24 - Ok
12/16/2020 4:04:15 PM: Read tracks on head 1 zone 24 - errors: 100, success: 0
12/16/2020 4:05:52 PM: Write tracks on head 1 zone 25 - Ok
12/16/2020 4:14:32 PM: Read tracks on head 1 zone 25 - errors: 100, success: 0
12/16/2020 4:16:19 PM: Write tracks on head 1 zone 26 - errors: 33, success: 67
12/16/2020 4:24:58 PM: Read tracks on head 1 zone 26 - errors: 100, success: 0
12/16/2020 4:26:34 PM: Write tracks on head 1 zone 27 - Ok
12/16/2020 4:35:05 PM: Read tracks on head 1 zone 27 - errors: 100, success: 0
12/16/2020 4:36:38 PM: Write tracks on head 1 zone 28 - Ok
12/16/2020 4:45:11 PM: Read tracks on head 1 zone 28 - errors: 100, success: 0
12/16/2020 4:47:00 PM: Write tracks on head 1 zone 29 - errors: 17, success: 83
12/16/2020 4:55:49 PM: Read tracks on head 1 zone 29 - errors: 100, success: 0
12/16/2020 4:59:21 PM: Write tracks on head 1 zone 30 - errors: 37, success: 63
12/16/2020 5:08:09 PM: Read tracks on head 1 zone 30 - errors: 100, success: 0
12/16/2020 5:09:44 PM: Write tracks on head 1 zone 31 - errors: 2, success: 98
12/16/2020 5:18:42 PM: Read tracks on head 1 zone 31 - errors: 100, success: 0
12/16/2020 5:20:12 PM: Write tracks on head 1 zone 32 - Ok
12/16/2020 5:29:52 PM: Read tracks on head 1 zone 32 - errors: 100, success: 0
12/16/2020 5:31:25 PM: Write tracks on head 1 zone 33 - Ok
12/16/2020 5:40:58 PM: Read tracks on head 1 zone 33 - errors: 100, success: 0
12/16/2020 5:42:27 PM: Write tracks on head 1 zone 34 - errors: 1, success: 99
12/16/2020 5:52:02 PM: Read tracks on head 1 zone 34 - errors: 100, success: 0
12/16/2020 5:53:29 PM: Write tracks on head 1 zone 35 - Ok
12/16/2020 6:03:08 PM: Read tracks on head 1 zone 35 - errors: 100, success: 0
12/16/2020 6:04:34 PM: Write tracks on head 1 zone 36 - errors: 1, success: 99
12/16/2020 6:14:15 PM: Read tracks on head 1 zone 36 - errors: 100, success: 0
12/16/2020 6:15:44 PM: Write tracks on head 1 zone 37 - Ok
12/16/2020 6:25:40 PM: Read tracks on head 1 zone 37 - errors: 100, success: 0
12/16/2020 6:27:18 PM: Write tracks on head 1 zone 38 - Ok
12/16/2020 6:37:16 PM: Read tracks on head 1 zone 38 - errors: 100, success: 0
12/16/2020 6:38:40 PM: Write tracks on head 1 zone 39 - Ok
12/16/2020 6:48:37 PM: Read tracks on head 1 zone 39 - errors: 100, success: 0
12/16/2020 6:49:59 PM: Write tracks on head 1 zone 40 - Ok
12/16/2020 6:59:52 PM: Read tracks on head 1 zone 40 - errors: 100, success: 0
12/16/2020 7:01:13 PM: Write tracks on head 1 zone 41 - Ok
It may be time for a new paper weight? This is in the user zone. The previous test was in SA.
Users browsing this forum: No registered users and 268 guests
