 Post subject: WDC WD20PURZ-85GU6Y0 ARCO process.
PostPosted: December 15th, 2020, 8:54
I am using WDmarvel for this process and getting an error.
12/12/2020 7:37:29 AM: Drive: WDC WD20PURZ-85GU6Y0, family: Diablo 3S (Royl), FW: 15.AFC, SN: WDC-ROM SN# XYZ----, LBA 1 - 0Gb
12/12/2020 7:37:30 AM: Media manufacturer code - J
12/12/2020 7:37:30 AM: Head manufacturer code - F
12/12/2020 7:37:31 AM: Error determining the number of options for DCM, state - Module not in Dir???
12/12/2020 7:37:31 AM: Error determining the number of Capacity Groups, state - VSC_ERR_UNSUP_ACTION_CODE
12/12/2020 7:38:01 AM: Test Parameters TPI Calibration not found
12/12/2020 7:38:01 AM: Test Parameters VDT HeadQual not found
12/12/2020 7:38:09 AM: Test Parameters Target Search Calibration not found
12/12/2020 7:40:24 AM: Media manufacturer code - J
12/12/2020 7:40:24 AM: Head manufacturer code - F
12/12/2020 7:40:24 AM: Error determining the number of options for DCM, state - Module not in Dir???
12/12/2020 7:40:47 AM: Drive: WDC WD20PURZ-85GU6Y0, family: Diablo 3S (Royl), FW: 15.AFC, SN: WDC-ROM SN# XYZ----, LBA 1 - 0Gb
12/12/2020 7:40:56 AM: Media manufacturer code - J
12/12/2020 7:40:56 AM: Head manufacturer code - F
12/12/2020 7:40:57 AM: Error determining the number of options for DCM, state - Module not in Dir???
12/12/2020 7:44:46 AM: Drive: WDC WD20PURZ-85GU6Y0, family: Diablo 3S (Royl), FW: 15.AFC, SN: WDC-ROM SN# XYZ----, LBA 1 - 0Gb
12/12/2020 7:44:47 AM: Media manufacturer code - J
12/12/2020 7:44:47 AM: Head manufacturer code - F
12/12/2020 7:44:48 AM: Error determining the number of options for DCM, state - Module not in Dir???
12/12/2020 7:44:48 AM: Error determining the number of Capacity Groups, state - VSC_ERR_UNSUP_ACTION_CODE
12/12/2020 7:45:18 AM: Test Parameters TPI Calibration not found
12/12/2020 7:45:18 AM: Test Parameters VDT HeadQual not found
12/12/2020 7:45:25 AM: Test Parameters Target Search Calibration not found
12/12/2020 7:46:07 AM: Media manufacturer code - J
12/12/2020 7:46:07 AM: Head manufacturer code - F
12/12/2020 7:46:08 AM: Error determining the number of options for DCM, state - Module not in Dir???
12/12/2020 7:46:27 AM: Drive: WDC WD20PURZ-85GU6Y0, family: Diablo 3S (Royl), FW: 15.AFC, SN: WDC-ROM SN# XYZ----, LBA 1 - 0Gb
12/12/2020 7:47:05 AM: Êîä ïðîèçâîäèòåëÿ ïëàñòèí - J
12/12/2020 7:47:05 AM: Êîä ïðîèçâîäèòåëÿ ãîëîâîê - F
12/12/2020 7:47:26 AM: Media manufacturer code - J
12/12/2020 7:47:26 AM: Head manufacturer code - F
12/12/2020 7:47:27 AM: Error determining the number of options for DCM, state - Module not in Dir???
12/12/2020 7:47:45 AM: Drive: WDC WD20PURZ-85GU6Y0, family: Diablo 3S (Royl), FW: 15.AFC, SN: WDC-ROM SN# XYZ----, LBA 1 - 0Gb
12/12/2020 7:47:46 AM: Media manufacturer code - J
12/12/2020 7:47:46 AM: Head manufacturer code - F
12/12/2020 7:47:47 AM: Error determining the number of options for DCM, state - Module not in Dir???
12/12/2020 7:47:47 AM: Error determining the number of Capacity Groups, state - VSC_ERR_UNSUP_ACTION_CODE
12/12/2020 7:48:16 AM: Test Parameters TPI Calibration not found
12/12/2020 7:48:16 AM: Test Parameters VDT HeadQual not found
12/12/2020 7:48:22 AM: Test Parameters Target Search Calibration not found
12/12/2020 7:48:54 AM: Region map successfully changed
12/12/2020 7:48:55 AM: Region map successfully changed
12/12/2020 7:49:17 AM: Overlays successfully loaded to RAM
12/12/2020 7:49:17 AM: Region map successfully restored
12/12/2020 7:49:18 AM: Region map successfully restored
12/12/2020 7:49:20 AM: ROM successfully read
12/12/2020 7:49:24 AM: ROM successfully erased
12/12/2020 7:49:26 AM: ROM successfully written
12/12/2020 7:49:41 AM: FW restarted (Reset immediate)
12/12/2020 7:49:46 AM: Head map successfully changed
12/12/2020 7:49:51 AM: FW restarted (Reset immediate)
12/12/2020 7:49:57 AM: Calibrator test MiniCalLin successfully launched
12/12/2020 7:54:55 AM: Calibrator test MiniCalLin completed successfully
12/12/2020 7:54:55 AM: Elapsed time 00:04:58
12/12/2020 7:55:01 AM: FW restarted (Reset immediate)
12/12/2020 7:55:06 AM: Calibrator test Mini ARCO successfully launched
12/12/2020 8:34:58 AM: Calibrator test Mini ARCO completed successfully
12/12/2020 8:34:58 AM: Elapsed time 00:39:52
12/12/2020 8:35:04 AM: FW restarted (Reset immediate)
12/12/2020 8:35:08 AM: Calibrator test Mini Write WRRO successfully launched
12/12/2020 8:39:11 AM: Calibrator test Mini Write WRRO completed successfully
12/12/2020 8:39:11 AM: Elapsed time 00:04:03
12/12/2020 8:39:17 AM: FW restarted (Reset immediate)
12/12/2020 8:39:21 AM: Calibrator test MiniIBI successfully launched
12/12/2020 8:42:33 AM: Calibrator test MiniIBI completed successfully
12/12/2020 8:42:34 AM: Elapsed time 00:03:12
12/12/2020 8:42:39 AM: FW restarted (Reset immediate)
12/12/2020 8:42:44 AM: Writing modules ...
12/12/2020 8:44:08 AM: Models list successfully changed.
12/12/2020 8:50:21 AM: Region map successfully changed
12/12/2020 8:50:22 AM: Region map successfully changed
12/12/2020 8:50:31 AM: Overlays successfully loaded to RAM
12/12/2020 8:50:31 AM: Region map successfully restored
12/12/2020 8:50:32 AM: Region map successfully restored
12/12/2020 8:50:37 AM: Successfully wrote 421 modules
12/12/2020 8:50:38 AM: Region map successfully changed
12/12/2020 8:50:39 AM: Region map successfully changed
12/12/2020 8:50:48 AM: Overlays successfully loaded to RAM
12/12/2020 8:50:48 AM: Region map successfully restored
12/12/2020 8:50:49 AM: Region map successfully restored
12/12/2020 8:50:50 AM: FW restarted (Reset immediate)
12/12/2020 8:51:23 AM: Set DCM success
12/12/2020 8:51:32 AM: FW restarted (Reset immediate)
12/12/2020 8:51:39 AM: UCCM Config is successfully set
12/12/2020 8:51:42 AM: RRO initialization successful
12/12/2020 8:51:45 AM: MRR initialization successful
12/12/2020 8:52:02 AM: Set DCM success
12/12/2020 8:52:08 AM: FW restarted (Reset immediate)
12/12/2020 8:55:19 AM: Error reading module IDE0, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 8:55:36 AM: Error reading module IDE8, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 8:55:38 AM: Successfully read 416 modules
12/12/2020 8:55:40 AM: ROM successfully read
12/12/2020 8:55:43 AM: Successfully read 7 modules
12/12/2020 8:55:45 AM: New format type drive detected
12/12/2020 8:56:18 AM: Restore point created with errors
12/12/2020 8:56:21 AM: Calibrator test Servo Process Util successfully launched
12/12/2020 8:56:25 AM: Calibrator test Servo Process Util completed successfully
12/12/2020 8:56:25 AM: Elapsed time 00:00:03
12/12/2020 8:56:31 AM: FW restarted (Reset immediate)
12/12/2020 8:59:37 AM: Error reading module IDE0, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 8:59:53 AM: Error reading module IDE8, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 8:59:55 AM: Successfully read 416 modules
12/12/2020 8:59:57 AM: ROM successfully read
12/12/2020 9:00:00 AM: Successfully read 7 modules
12/12/2020 9:00:01 AM: New format type drive detected
12/12/2020 9:00:35 AM: Restore point created with errors
12/12/2020 9:00:38 AM: Calibrator test Servo Calibration successfully launched
12/12/2020 9:14:31 AM: Calibrator test Servo Calibration completed successfully
12/12/2020 9:14:31 AM: Elapsed time 00:13:52
12/12/2020 9:14:38 AM: FW restarted (Reset immediate)
12/12/2020 9:17:46 AM: Error reading module IDE0, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 9:18:00 AM: Error reading module IDE8, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 9:18:02 AM: Successfully read 416 modules
12/12/2020 9:18:04 AM: ROM successfully read
12/12/2020 9:18:07 AM: Successfully read 7 modules
12/12/2020 9:18:08 AM: New format type drive detected
12/12/2020 9:18:41 AM: Restore point created with errors
12/12/2020 9:18:45 AM: Calibrator test TouchDown Calibration successfully launched
12/12/2020 10:34:53 AM: Calibrator test TouchDown Calibration completed successfully
12/12/2020 10:34:53 AM: Elapsed time 01:16:07
12/12/2020 10:34:59 AM: FW restarted (Reset immediate)
12/12/2020 10:38:07 AM: Error reading module IDE0, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 10:38:24 AM: Error reading module IDE8, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 10:38:32 AM: Successfully read 421 modules
12/12/2020 10:38:34 AM: ROM successfully read
12/12/2020 10:38:37 AM: Successfully read 7 modules
12/12/2020 10:38:39 AM: New format type drive detected
12/12/2020 10:39:10 AM: Restore point created with errors
12/12/2020 10:39:14 AM: Calibrator test RWGap Calibration successfully launched
12/12/2020 10:49:49 AM: Calibrator test RWGap Calibration completed successfully
12/12/2020 10:49:49 AM: Elapsed time 00:10:34
12/12/2020 10:49:56 AM: FW restarted (Reset immediate)
12/12/2020 10:53:04 AM: Error reading module IDE0, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 10:53:20 AM: Error reading module IDE8, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
12/12/2020 10:53:30 AM: Successfully read 427 modules
12/12/2020 10:53:32 AM: ROM successfully read
12/12/2020 10:53:34 AM: Successfully read 7 modules
12/12/2020 10:53:36 AM: New format type drive detected
12/12/2020 10:54:09 AM: Restore point created with errors
12/12/2020 10:54:13 AM: Error setting Target Capacity, state - VSC_ERR_UNSUP_ACTION_CODE
12/12/2020 10:54:29 AM: Target Capacity was set to 1
12/12/2020 10:54:32 AM: Calibrator test Zone TPI calc and HeadQual successfully launched
12/12/2020 2:30:09 PM: Test Zone TPI calc and HeadQual failed with error: ARCO Error - ARCO Data placement invalid
12/12/2020 2:30:10 PM: Elapsed time 03:35:37
Anyone have an idea why this stopped here and what to try?
 Post subject: Re: WDC WD20PURZ-85GU6Y0 ARCO process.
PostPosted: December 15th, 2020, 14:45
ARCO is not an easy task. You must learn much before trying to run an ARCO process. Don't ignore the error messages as well.
PostPosted: December 15th, 2020, 20:55
I ran ARCO on the drive as suggested by Vlad. I posted on that forum too, but have not received an answer.
Users browsing this forum: No registered users and 300 guests
