 Post subject: Your advice : Heads or pcb ?
PostPosted: November 16th, 2020, 12:04
Hello HDD Guru's board !
First, I'm sorry, it's my firt post here and it's for requesting help :roll: :oops:
I read some interesting stuff here and I think you can help me.
I have a respectable skill on microsoldering and digital stuff but poor knowledge on HDD recovery (some true success with testdisk, nothing more)
Let's GO
It's about a 1To WD Elements 2,5" USB 3
A day,
- drive letter not showing on windows 10
- Cold start : drive spinning normally and USB bridge detected. And after 1mn -> clak sound/spin down/spin up and then drive appear in device manager (and stay in this state)
- No drive letter and in Windows Disk manager disk appear "not allocated" Unknow state and ask me to choose initialization method...
Testdisk show only "read error" at first step (analysis)
What do you think about this ? Head problem ? or PCB problem ? what's your advices ?
Thank you very much !
Best regards :good:
Stephane
a little more data about this disk :
WDBUZG0010BBK-EESN
WD ELEMENTS PORTABLE 1TB BLACK
EMEA 1-Oct-2016
Windows WD Tool
Test Option: QUICK TEST
Model Number: WD Elements 1078
Unit Serial Number: WX41E44YTY07
Firmware Number: 1065
Capacity: 1000.17 GB
SMART Status: Not Available
Test Result: FAIL
Test Error Code: 08-Too many bad sectors detected.
Test Time: 14:28:13, November 16, 2020
Test Option: EXTENDED TEST
Test Result: FAIL
Test Time: 14:28:53, November 16, 2020
References on Drive and board :
Model : WD10JMVW
DCX : YA30J45GT
DCM : SBKT2HB
DATE : 12 JUL 2014
WWN : 50014EE65A 14DD52 USB
MDL : WD10JMVW-11AJGS3
PCB ref :
2060-771961-001 RevA
 Post subject: Re: Your advice : Heads or pcb ?
PostPosted: November 17th, 2020, 4:38
Probably one (or more) weak heads.
ACELab partner
PostPosted: November 17th, 2020, 7:28
If your data is important and you can afford to pay, get it to a professional to recover it; we need to make a living too.
To try a DIY solution get the drive or as much as you can cloned first - https://forum.hddguru.com/viewtopic.php?f=1&t=40561 will give you an idea of how you can do this with free software but be aware that using the drive may be degrading it.
PostPosted: November 17th, 2020, 11:55
careful, you might get eaten by some here :)
PostPosted: November 19th, 2020, 4:42
Only for reasonnably hungry guy :mrgreen:
Recovery offers PM are welcome :agree: (I'm from France, Europe mailing Ok)
really difficult to evaluate amount of data, but probably less than 10Gb
Thank you for your advices
Stephane
PostPosted: December 17th, 2020, 6:06
I'm sorry for this late update, crazy work in december :horse:
Thank you to pcimage, pclab, DRUG & samstown for your offers (your prices are appromatively the same between 150 (easy mode) up to 350 if head swap)
Why I choose samstown ? the nearest from my home, price in the middle range, speak french
Job perfectly done ! Thank you samstown !
Big thank you to hddguru for this forum !
See you next time ! :mrgreen:
Stephane
PostPosted: December 18th, 2020, 2:57
Thank you
PostPosted: December 18th, 2020, 10:43
I believe it was ( easy mode ) without replacing heads.
Typical issue of slow response ( power up, not showing then spin down and spin up again )
Congrats
Job well done.
Users browsing this forum: Bing [Bot], Google [Bot] and 48 guests
