 Post subject: Increasing "Number of Reported Uncorrectable Errors"
PostPosted: December 20th, 2020, 16:31
My first post here. I searched everywhere in the Internet but so far I have not found any good answer.
I have one "Seagate BarraCuda 3.5 ST4000DM004" which is somewhat new (purchased a little over 6 months ago).
It is installed on a Synology NAS and it is running 24x7 (I know, it is an SMR drive and should not be used as a NAS disk, but I have an online backup and the important things are sycnhed also with a cloud service).
My question is regarding the following SMART statistics:
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4              14  ---  Number of Reported Uncorrectable Errors
This number is shown when running smartctl with a "-x" option (smartctl -x /dev/sda).
The problem is that this number was zero when the drive was new, and it is increasing about 2 errors/month.
However, this shows only when using "smartctl -x" and the standard "187" SMART is zero:
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME                                                   FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
187 Reported_Uncorrect                                               -O--CK   100   100   000    -    0
197 Current_Pending_Sector                                           -O--C-   100   100   000    -    0
198 Offline_Uncorrectable                                            ----C-   100   100   000    -    0
So the question is: how the statistics are showing an increasing number of "Number of Reported Uncorrectable Errors" but the S.M.A.R.T. attribute "187 Reported_Uncorrect " does not report anything?
Should I worry about this disk failing soon?
Attached is the full smartctl output.
Thanks!
smartctl.txt [18.23 KiB]
Downloaded 1762 times
 Post subject: Re: Increasing "Number of Reported Uncorrectable Errors"
PostPosted: December 23rd, 2020, 11:18
Your Hard Drive Current_Pending_Sector is 0 so most probably all sectors are good.
PostPosted: December 23rd, 2020, 21:40
Thank you for your reply. This is also my understanding. I’ve run SATA extended tests as well as Synology volume scrubbing. No errors were reported, but after these two tests the statistics of "Number of Reported Uncorrectable Errors" increased to 17. I have another drive of the same model and this statistic data is zero.
I will keep an eye on the standard SMART Current_Pending_Sector and Reported_Uncorrect which are still reporting as zero. For now I will assume that this ”Number of Reported Uncorrectable Errors" reported only with “smart to -x” in the statistics session does not represent a potencial problem (unless I can find some reliable documentation about the meaning of this value).
Thanks!
PostPosted: July 14th, 2021, 8:07
Well, after a few months I'm returning here to document this issue and my findings just in case someone else has the same issue.
In my first post I missed to mention that I'm running BTRFS on this drive. Since then I've received a dozen "Checksum Mismatch" erros on random files.
And I have confirmed that these were in fact corrupted files, and I had to restore these files from backup.
The interesting thing is that no bad sector nor any SMART were was reported. I even run and "Extended SMART Test" that took several hours and it completed without errors. As you can see below the standard SMART values are all OK:
  1 Raw_Read_Error_Rate                                              POSR--   076   064   006    -    37021224
  3 Spin_Up_Time                                                     PO----   096   096   000    -    0
  4 Start_Stop_Count                                                 -O--CK   100   100   020    -    35
  5 Reallocated_Sector_Ct                                            PO--CK   100   100   010    -    0
  7 Seek_Error_Rate                                                  POSR--   080   060   045    -    96894512
  9 Power_On_Hours                                                   -O--CK   087   087   000    -    11750 (99 52 0)
10 Spin_Retry_Count                                                 PO--C-   100   100   097    -    0
12 Power_Cycle_Count                                                -O--CK   100   100   020    -    35
183 Runtime_Bad_Block                                                -O--CK   100   100   000    -    0
184 End-to-End_Error                                                 -O--CK   100   100   099    -    0
188 Command_Timeout                                                  -O--CK   100   100   000    -    0 0 0
189 High_Fly_Writes                                                  -O-RCK   100   100   000    -    0
190 Airflow_Temperature_Cel                                          -O---K   069   058   040    -    31 (Min/Max 25/33)
191 G-Sense_Error_Rate                                               -O--CK   100   100   000    -    0
192 Power-Off_Retract_Count                                          -O--CK   100   100   000    -    449
193 Load_Cycle_Count                                                 -O--CK   100   100   000    -    508
194 Temperature_Celsius                                              -O---K   031   042   000    -    31 (0 22 0 0 0)
195 Hardware_ECC_Recovered                                           -O-RC-   076   064   000    -    37021224
199 UDMA_CRC_Error_Count                                             -OSRCK   200   200   000    -    0
240 Head_Flying_Hours                                                ------   100   253   000    -    8813h+14m+19.236s
241 Total_LBAs_Written                                               ------   100   253   000    -    8106501321
242 Total_LBAs_Read                                                  ------   100   253   000    -    33554198868
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     11744         -
# 2  Short offline       Completed without error       00%     11644         -
# 3  Short offline       Completed without error       00%     10924         -
# 4  Short offline       Completed without error       00%     10180         -
# 5  Short offline       Completed without error       00%      9477         -
# 6  Short offline       Completed without error       00%      8733         -
# 7  Short offline       Completed without error       00%      8061         -
# 8  Short offline       Completed without error       00%      7317         -
# 9  Extended offline    Completed without error       00%      6824         -
#10  Short offline       Completed without error       00%      6810         -
#11  Short offline       Completed without error       00%      6573         -
#12  Short offline       Completed without error       00%      5853         -
#13  Short offline       Completed without error       00%      5109         -
#14  Short offline       Completed without error       00%      4389         -
#15  Short offline       Completed without error       00%      3645         -
#16  Short offline       Completed without error       00%      2901         -
#17  Short offline       Completed without error       00%      2181         -
#18  Short offline       Completed without error       00%      1439         -
#19  Short offline       Completed without error       00%       722         -
However this drive is IN FACT FAILING, as confirmed by the btrfs "checksum mismatch" erros and confirmed that the reported files were in fact corrupt. And as I mentioned in the original post the "Number of Reported Uncorrectable Errors" in the SMART Device Statistics kept increasing, now 20 (more or less consistend with the number of "checksum mismatch" errors from btrfs:
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              35  ---  Lifetime Power-On Resets
0x01  0x010  4           11750  ---  Power-on Hours
0x01  0x018  6      8106535977  ---  Logical Sectors Written
0x01  0x020  6        24955511  ---  Number of Write Commands
0x01  0x028  6     33554198868  ---  Logical Sectors Read
0x01  0x030  6        38612416  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           11749  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11746  ---  Head Flying Hours
0x03  0x018  4             508  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4             449  ---  Number of High Priority Unload Events
0x04  0x008  4              20  ---  Number of Reported Uncorrectable Errors <<<<<< !!!!!!!!!!!!!!!!!!!!!
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              31  ---  Current Temperature
0x05  0x010  1              31  ---  Average Short Term Temperature
0x05  0x018  1              28  ---  Average Long Term Temperature
0x05  0x020  1              42  ---  Highest Temperature
0x05  0x028  1               0  ---  Lowest Temperature
0x05  0x030  1              39  ---  Highest Average Short Term Temperature
0x05  0x038  1              23  ---  Lowest Average Short Term Temperature
0x05  0x040  1              36  ---  Highest Average Long Term Temperature
0x05  0x048  1              27  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4               0  ---  Number of Hardware Resets
0x06  0x010  4               0  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
I have another drive of the exact same model, age and usage and this other drive has "0" in the "Number of Reported Uncorrectable Errors" value.
At this point I just replaced this drive and will try an RMA, since I cannot trust it anymore.
And it is really strange. I just detected this problem because of the BTRFS checksum feature. Otherwise I would just be getting corrupted files without any notification from the drive. I would just consider bit rot and I would never suspect the drive if the "Number of Reported Uncorrectable Errors" statistics would not keep increasing...
PostPosted: July 14th, 2021, 12:17
I see three SMART parameters with abnormal high figures that do not go well with such a new drive.
It appears like a interface problem.
PostPosted: July 14th, 2021, 14:55
I notice that Head Flying Hours also differs.
I would submit a critical bug report to Seagate in respect of the misreporting of uncorrectable errors. I doubt they will do anything, though, if my past personal experience is any guide.
PostPosted: July 14th, 2021, 15:33
Which ones? I mean, I have two disks of the exact same model running in RAID0, with similar statistics, execpt the "Number of Reported Uncorrectable Errors". See attached the full SMART output of these two drives just in case (I have only edited out the serial number for privacy reasons).
Anyway, yesterday I replaced the drive that is supposedly failing by a new one of the same model, let's see how things will turn out.
HDD-Bad.txt [17.73 KiB]
Downloaded 1622 times
HDD-Good.txt [18.3 KiB]
Downloaded 1666 times
PostPosted: July 14th, 2021, 15:36
Honestly I also believe they will do nothing, so probably it will be a waste of my time. Anyway the HDD is still under warranty and I will request an RMA.
PostPosted: July 15th, 2021, 10:40
OK, I just connected the problematic drive to a Windows PC and I'm running the "Long Generic" test from Sea Tools.
Again the "Number of Reported Uncorrectable Errors" keep increasing in the statistics, but all other SMART values are OK.
I have 4 other drives of the same model (being 1 brand new that replaced the failing HDD) and all of them are reporting "0" in this statistics.
Seagate RMA policy says that the drive must be failing to be eligible for replacement under warranty, and so far all tests I've executed returned OK, despite the fact that files stored in this hard disk as getting corrupted.
I am considering this as a bad drive, however I am afraid that Seagate might not replace it via RMA (it is still under warranty) because none of the SMART tests are reporting errors. My last hope is that Sea Tools might find something, let's see.
PostPosted: July 15th, 2021, 10:57
dsouza,
Victoria - Write + DDD.
PostPosted: July 15th, 2021, 14:04
See https://www.seagate.com/staticfiles/support/seatools/seatools-test-codes.html
A SeaTools Test Code is important when returning a Seagate product under warranty. The SeaTools Test Code proves that the drive has failed diagnostic tests performed by SeaTools.
Seagate understands that there are several legitimate reasons why you might not have a SeaTools Test Code. Please review the following suggestions and if you still need a Self-Service test Code, copy the 8-digit code from the one of the choices below and paste it in to the SeaTools Test Code field on the RMA form.
PostPosted: July 15th, 2021, 14:38
fzabkar,
universal to get RMA:
CA99C4AC - SeaTools could not detect my drive
no one checks further.
PostPosted: July 16th, 2021, 8:48
Those ones:
1 Raw_Read_Error_Rate POSR-- 083 064 006 - 191398272
7 Seek_Error_Rate POSR-- 077 060 045 - 49409103
195 Hardware_ECC_Recovered -O-RC- 083 064 000 - 191398272
PostPosted: July 16th, 2021, 12:38
Those ones:
Those are normal.
Seagate's Seek Error Rate, Raw Read Error Rate, and Hardware ECC Recovered SMART attributes:
http://www.users.on.net/~fzabkar/HDD/Seagate_SER_RRER_HEC.html
Seagate SMART Attribute Specification:
http://t1.daumcdn.net/brunch/service/user/axm/file/zRYOdwPu3OMoKYmBOby1fEEQEbU.pdf
Normal SATA SMART Attribute Behavior (Seagate):
http://t1.daumcdn.net/brunch/service/user/axm/file/Vw3RJSZllYbDc86ssL6bofiL4r0.pdf
PostPosted: July 16th, 2021, 14:52
Those ones:
Those are normal.
Thanks. That's my understanding too (these values are normal).
PostPosted: July 18th, 2021, 13:27
Hello fzabkar,
rec wrote:
dsouza wrote:
Those are normal.
thanks a lot for letting me learn it!
:cool:
PostPosted: July 19th, 2021, 17:15
Well, I submitted a bug report to Seagate. They did assign a person to follow up this bug, but he claims that "due to our firewall security restrictions we cannot open any 3rd party link". He did request screenshots of this thread, but I think people will agree that this is beyond reason.
<sigh>
PostPosted: July 27th, 2021, 18:54
As I see it, it's an obvious bug, but according to Seagate ...
Dear Franc,
Thank you once again for contacting Seagate Support and for your feedback and input.
As request we have escalated this case to our manager who took the time to review the issue reported on the forwarded forum link.
>From the description of the users involved on the forum we understood that a user reported an increase on the uncorrectable SMART value errors while using a Barracuda drive on a Synology system.
Please be aware that our Barracuda internal hard drive, specifically the drive with model number ST4000DM004 is not intended to be used within a NAS device or as part of a RAID. For this type of application we recommend instead our Seagate IronWolf drive models. The usage of such drive in a non compatible/tested/designed environment can cause discrepancies on the SMART values as well as unexpected behaviors for the drive. There is also the possibility that the drive was not listed in the compatibility list of the Synology device model which can lead to this type of issues.
Unusual or high increase of SMART attributes such as uncorrectable errors or Head Flying hours are usually an indication that either the drive is failing or is being used on a non compatible - best fit application/device.
Considering that we do not hold any further information from the environment, details of the devices or action held on this drive, is hard to determine with accuracy the root of the issue but taking into account what was described by the user, we would consider the drive as faulty.
This type of issue can happen due to many factors and does not necessarily mean that it is a bug that affects all of our drives and compatible systems but rather a possible failure that somehow led to data corruption or damage on the media sectors.
We can assure you our Barracuda drives on a standard usage environment are used without any issue and so far we have not received any data corruption reports for this model or any similar issue, so you can understand why we cannot treat this issue as general bug for all our drives.
We appreciate very much your time to report this issue and we want to let you know that we take very seriously this type of situations as it helps us improve our products and services.
For the moment we wont be able to investigate the issue further as we are not able to gather more information from the user that reported the issue but rest assure that we will continue to collect feedback from our Customers in regards to this drive in case there is any other similar issue reported.
Best Regards,
Miltos
Seagate Customer Support Team
PostPosted: August 14th, 2021, 22:47
Thank you!
PostPosted: August 14th, 2021, 22:56
BTW, I am keeping the "suspected drive" connected to a Windows PC (a headless unit I keep 24x7 for some other purposes). I've installed BRTFS for Windows (I know, ti is not really stable), formatted the drive with BRTFS and copied a lot of data to it.
From time to time I will do some writing to this disk and also do a data scrubbing to see if some part of the disk is experiencing "bit rotting" (which is what I believe it was happening when this disk was connected to the Synology NAS).
I will update here in case I see the "Number of Reported Uncorrectable Errors" statistics will increase after some time (it is right now at "33" after a bunch of tests I performed with this disk).
C:\>smartctl -x /dev/sdb
smartctl 7.2 2020-12-15 r5131 [x86_64-w64-mingw32-w10-b19043] (CircleCI)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate BarraCuda 3.5
Device Model:     ST4000DM004-2CV104
Serial Number:    XXXXXXXX
LU WWN Device Id: XXXXXXXXXXXXXXXXXXX
Firmware Version: 0001
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5425 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Aug 14 23:53:43 2021 ESAST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (    0) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 498) minutes.
Conveyance self-test routine
recommended polling time:        (   2) minutes.
SCT capabilities:              (0x30a5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     POSR--   073   064   006    -    19651948
  4 Start_Stop_Count        -O--CK   100   100   020    -    817
  7 Seek_Error_Rate         POSR--   081   060   045    -    121049868
  9 Power_On_Hours          -O--CK   086   086   000    -    12564 (189 6 0)
12 Power_Cycle_Count       -O--CK   100   100   020    -    43
190 Airflow_Temperature_Cel -O---K   069   058   040    -    31 (Min/Max 21/35)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    452
193 Load_Cycle_Count        -O--CK   099   099   000    -    2321
194 Temperature_Celsius     -O---K   031   042   000    -    31 (0 21 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   073   064   000    -    19651948
240 Head_Flying_Hours       ------   100   253   000    -    9167h+38m+16.789s
241 Total_LBAs_Written      ------   100   253   000    -    39175856966
242 Total_LBAs_Read         ------   100   253   000    -    86189820653
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    512  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      24  Device vendor specific log
0xa2       GPL     VS    8160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xb0       GPL     VS    9048  Device vendor specific log
0xbd       GPL     VS       8  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL,SL  VS      16  Device vendor specific log
0xc3       GPL,SL  VS       8  Device vendor specific log
0xc4       GPL,SL  VS      24  Device vendor specific log
0xd1       GPL     VS     264  Device vendor specific log
0xd3       GPL     VS    1920  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
# 1  Extended offline    Aborted by host               90%     11887         -
# 2  Short offline       Completed without error       00%     11819         -
# 3  Extended offline    Completed without error       00%     11744         -
# 4  Short offline       Completed without error       00%     11644         -
# 5  Short offline       Completed without error       00%     10924         -
# 6  Short offline       Completed without error       00%     10180         -
# 7  Short offline       Completed without error       00%      9477         -
# 8  Short offline       Completed without error       00%      8733         -
# 9  Short offline       Completed without error       00%      8061         -
#10  Short offline       Completed without error       00%      7317         -
#11  Extended offline    Completed without error       00%      6824         -
#12  Short offline       Completed without error       00%      6810         -
#13  Short offline       Completed without error       00%      6573         -
#14  Short offline       Completed without error       00%      5853         -
#15  Short offline       Completed without error       00%      5109         -
#16  Short offline       Completed without error       00%      4389         -
#17  Short offline       Completed without error       00%      3645         -
#18  Short offline       Completed without error       00%      2901         -
#19  Short offline       Completed without error       00%      2181         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     21/35 Celsius
Lifetime    Min/Max Temperature:     21/42 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         3 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:     14/55 Celsius
Min/Max Temperature Limit:           10/60 Celsius
Temperature History Size (Index):    128 (115)
Index    Estimated Time   Temperature Celsius
116    2021-08-09 18:39    31  ************
117    2021-08-09 19:38    31  ************
118    2021-08-09 20:37    34  ***************
119    2021-08-09 21:36    33  **************
120    2021-08-09 22:35    34  ***************
121    2021-08-09 23:34    30  ***********
122    2021-08-10 00:33    29  **********
123    2021-08-10 01:32    30  ***********
124    2021-08-10 02:31    31  ************
125    2021-08-10 03:30    31  ************
126    2021-08-10 04:29    34  ***************
127    2021-08-10 05:28    34  ***************
   0    2021-08-10 06:27    31  ************
   1    2021-08-10 07:26    30  ***********
   2    2021-08-10 08:25    30  ***********
   3    2021-08-10 09:24    34  ***************
   4    2021-08-10 10:23    34  ***************
   5    2021-08-10 11:22    31  ************
   6    2021-08-10 12:21    31  ************
   7    2021-08-10 13:20    30  ***********
...    ..(  2 skipped).    ..  ***********
  10    2021-08-10 16:17    30  ***********
  11    2021-08-10 17:16    31  ************
  12    2021-08-10 18:15    29  **********
  13    2021-08-10 19:14    29  **********
  14    2021-08-10 20:13    29  **********
  15    2021-08-10 21:12    33  **************
  16    2021-08-10 22:11    32  *************
  17    2021-08-10 23:10    29  **********
  18    2021-08-11 00:09    29  **********
  19    2021-08-11 01:08    28  *********
  20    2021-08-11 02:07    28  *********
  21    2021-08-11 03:06    29  **********
  22    2021-08-11 04:05    32  *************
  23    2021-08-11 05:04    28  *********
  24    2021-08-11 06:03    33  **************
  25    2021-08-11 07:02    30  ***********
  26    2021-08-11 08:01    29  **********
  27    2021-08-11 09:00    28  *********
...    ..(  6 skipped).    ..  *********
  34    2021-08-11 15:53    28  *********
  35    2021-08-11 16:52    30  ***********
  36    2021-08-11 17:51    29  **********
  37    2021-08-11 18:50    29  **********
  38    2021-08-11 19:49    28  *********
  39    2021-08-11 20:48    29  **********
  40    2021-08-11 21:47    26  *******
  41    2021-08-11 22:46    30  ***********
  42    2021-08-11 23:45    29  **********
  43    2021-08-12 00:44    27  ********
  44    2021-08-12 01:43    30  ***********
  45    2021-08-12 02:42    27  ********
  46    2021-08-12 03:41    24  *****
  47    2021-08-12 04:40    27  ********
  48    2021-08-12 05:39    28  *********
  49    2021-08-12 06:38    25  ******
  50    2021-08-12 07:37    26  *******
  51    2021-08-12 08:36    27  ********
  52    2021-08-12 09:35    28  *********
  53    2021-08-12 10:34    28  *********
  54    2021-08-12 11:33    28  *********
  55    2021-08-12 12:32    26  *******
...    ..(  3 skipped).    ..  *******
  59    2021-08-12 16:28    26  *******
  60    2021-08-12 17:27    27  ********
  61    2021-08-12 18:26    28  *********
  62    2021-08-12 19:25    28  *********
  63    2021-08-12 20:24    28  *********
  64    2021-08-12 21:23    26  *******
  65    2021-08-12 22:22    29  **********
  66    2021-08-12 23:21    29  **********
  67    2021-08-13 00:20    27  ********
  68    2021-08-13 01:19    28  *********
  69    2021-08-13 02:18    30  ***********
  70    2021-08-13 03:17    26  *******
  71    2021-08-13 04:16    26  *******
  72    2021-08-13 05:15    26  *******
  73    2021-08-13 06:14    29  **********
  74    2021-08-13 07:13    25  ******
  75    2021-08-13 08:12    25  ******
  76    2021-08-13 09:11    27  ********
  77    2021-08-13 10:10    26  *******
  78    2021-08-13 11:09    27  ********
  79    2021-08-13 12:08    28  *********
  82    2021-08-13 15:05    28  *********
  83    2021-08-13 16:04    29  **********
  84    2021-08-13 17:03    28  *********
  85    2021-08-13 18:02    28  *********
  86    2021-08-13 19:01    27  ********
  87    2021-08-13 20:00    29  **********
  88    2021-08-13 20:59    28  *********
  89    2021-08-13 21:58    30  ***********
  90    2021-08-13 22:57    29  **********
  91    2021-08-13 23:56    27  ********
  92    2021-08-14 00:55    27  ********
  93    2021-08-14 01:54    28  *********
  94    2021-08-14 02:53    27  ********
  95    2021-08-14 03:52    27  ********
  96    2021-08-14 04:51    27  ********
  97    2021-08-14 05:50    28  *********
  98    2021-08-14 06:49    27  ********
  99    2021-08-14 07:48    27  ********
100    2021-08-14 08:47    27  ********
101    2021-08-14 09:46    28  *********
102    2021-08-14 10:45    28  *********
103    2021-08-14 11:44    28  *********
104    2021-08-14 12:43    29  **********
105    2021-08-14 13:42    28  *********
106    2021-08-14 14:41    29  **********
109    2021-08-14 17:38    29  **********
110    2021-08-14 18:37    30  ***********
111    2021-08-14 19:36    31  ************
112    2021-08-14 20:35    29  **********
113    2021-08-14 21:34    31  ************
114    2021-08-14 22:33    31  ************
115    2021-08-14 23:32    29  **********
SCT Error Recovery Control command not supported
0x01  0x008  4              43  ---  Lifetime Power-On Resets
0x01  0x010  4           12564  ---  Power-on Hours
0x01  0x018  6     39175891814  ---  Logical Sectors Written
0x01  0x020  6       171719238  ---  Number of Write Commands
0x01  0x028  6     86190060527  ---  Logical Sectors Read
0x01  0x030  6       254830092  ---  Number of Read Commands
0x01  0x038  6   1628375719725  ---  Date and Time TimeStamp
0x03  0x008  4           12208  ---  Spindle Motor Power-on Hours
0x03  0x010  4           12105  ---  Head Flying Hours
0x03  0x018  4            2321  ---  Head Load Events
0x03  0x040  4             452  ---  Number of High Priority Unload Events
0x04  0x008  4              33  ---  Number of Reported Uncorrectable Errors
0x05  0x010  1              27  ---  Average Short Term Temperature
0x06  0x008  4             610  ---  Number of Hardware Resets
0x06  0x010  4              17  ---  Number of ASR Events
                                ||__ D supports DSN
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2          545  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
C:\>
Users browsing this forum: DrZ and 62 guests
