WD Black 4TO ko
January 4th, 2021, 11:17
Hello, my WD HDD is no longer working. Most of my datas were backed up but I have some losses and I would like to try to recover this data + it's interesting to better understand how HDD works.
The problem: at launch (Sata), the disk spins then clicks a few times and seems blocked. I enclose a recording of the noise (mp3 in the archive).
In the bios the disk is detected with 0 Tb.
What do you think I can do to try to recover datas ?
What I tried:
- clean the contacts by unscrewing the PCB
- try to do a more in-depth diagnosis with the Hiren Boot 14.1 tools - without success
The HDD reference: WD4001FAEX-00MJRA0 / Firmware: 01.01L01
Purchased July 2013.
00069 - Copie_Trim.mp4.rar
WD HDD click
(221.96 KiB) Downloaded 639 times
Re: WD Black 4TO ko
January 4th, 2021, 14:38
I have not listened to the audio due to possible viruses.
Does the drive spin up, click and then shuts down, or click and continue spinning?
Re: WD Black 4TO ko
January 4th, 2021, 14:44
ddrecovery wrote:I have not listened to the audio due to possible viruses.
https://www.virustotal.com/gui/url/86553781cf222373d21358480369bc69cfe0ad3e762c44e243c96fd31cde82c9/detection
Only Google Safebrowsing detects it as "Malicious".
Re: WD Black 4TO ko
January 4th, 2021, 15:41
Unfortunately that does not sound like a DIY job.
Sounds very much like read-write head failure unfortunately.
Re: WD Black 4TO ko
January 4th, 2021, 17:15
Clicking WD is usually heads. Not a DIY fix.
Re: WD Black 4TO ko
January 4th, 2021, 17:59
Too bad, the noise did not seem really hopeful.
Thank you very much for your feedback.
I read in forum that some try to put HDDs in the fridge for 4-5 hours. Sometimes HDD can work briefly to back up datas. What do you think :?:
Re: WD Black 4TO ko
January 4th, 2021, 19:04
drumtpy wrote:Too bad, the noise did not seem really hopeful.
Absolutely NOT
Re: WD Black 4TO ko
January 5th, 2021, 19:38
This does not work.
Some guys here realized it the hard way, others just used their brain.
Old (really old) HDD's might have had a chsnce to work with that technique, if condensation and humidity was well taken care of, but new drives, no chance.
No chance at all.
