 Post subject: WD My Passpord 4TB 2060-800041-003 doesn't turn on
PostPosted: January 6th, 2021, 10:02
Hello everyone,
I've been trying to diagnose a 4TB 2,5 inch WD USB hard drive but I haven't managed to solve the problem. I've already ordered a new 2060-800041-003 PCB but I'd like to understand what happened to the current one.
At first the USB connection wasn't very well working, then it started not showing any sign of life and now when I connect the hard drive to the usb port nothing happens (not even the usb connection is found). Soldering points on the board all seem perfect. Is there any specific pin i should check? I tried looking for some kind of service manual but couldn't find any.
Thanks in advance :)
 Post subject: Re: WD My Passpord 4TB 2060-800041-003 doesn't turn on
PostPosted: January 6th, 2021, 16:33
Does it spin up?
https://groups.google.com/g/datarecoverycertification/c/brCrfGRr2LY
PostPosted: January 6th, 2021, 20:22
No signs of life unfortunately. Thanks for the picture and the link,I’ll check the hdd later
PostPosted: January 6th, 2021, 20:43
Omg.... THANKS! It was exactly the same problem the guy in the linked description was reporting. Thanks a lot.
I resoldered the zero ohm resistor and the hard drive came to life again :)
PostPosted: January 7th, 2021, 5:53
Nice one fzabkar
PostPosted: January 7th, 2021, 11:59
Spotmen wrote:
Nice one fzabkar
+1
PostPosted: January 8th, 2021, 7:06
I was wondering something else about the same hard disk.
When it was new it used to spin down right after unmounting it. In the last few days before the hardware failure it started not spinning down at all, but it was time to time. After the repair it's not spinning down at all, it properly unmounts but I have to unplug it with the platters still spinning. Is that caused by an hardware or software problem?
Would it be a software one, how could I fix it? Thanks in advance again :)
PostPosted: January 8th, 2021, 12:53
These drives autopark after an idle timeout. You can see this in the SMART report (Load/Unload Cycles). This behaviour is determined by the APM setting.
PostPosted: May 28th, 2021, 8:00
Today, I got the 0 ohm problem, thank you fzabkar
Users browsing this forum: Google [Bot] and 114 guests
