 Post subject: Seagate ST1000LM035, SimError - Remaining in BootFW
PostPosted: March 19th, 2021, 17:15
I've got an ST1000LM035 with the following terminal output:
Boot 0x80M[LBA=0x00000406 EC=][LBA=0x00000406 EC=]
DSC PASS[LBA=0x0000CF26 EC=][LBA=0x0000CF4F EC=][LBA=0x0000CF52 EC=][LBA=0x0000CF52 EC=]
00001002Perform a double download without a power cycle
QNR Boot:  Interface Reset Received.
Do you have any suggestions about what may be wrong with this drive, and where to look next?
Thanks,
Peter
 Post subject: Re: Seagate ST1000LM035, SimError - Remaining in BootFW
PostPosted: March 19th, 2021, 17:50
Hello Peter,
it's been a long time since we met, hasn't it? Good to hear from you, i hope you are fine!
Without tools and experience you got very slim chances against this drive but got a nice amount to screw it up more.
I would say it is either heads are weak or SA is damaged, or both.
I do have everything to provide the best possible results, if needed, it's just a call away...
PostPosted: March 21st, 2021, 10:38
+1, pepe is your best bet!
I'd say most probably SA is damaged, but weak heads and not native PCB are also possible.
PostPosted: March 23rd, 2021, 6:30
Thx Dmitris.
with non-native pcb it would fail at SA defect list, not at Discfw, so i kind of ruled that out. Anyway, we got in touch and discussed the matter, client declined the recovery, so the case is probably closed...
Users browsing this forum: Bing [Bot], Google [Bot] and 257 guests
