 Post subject: Toshiba PCB swap question
PostPosted: February 2nd, 2021, 21:46
Hello forum
I have a Toshiba USB drive, PCB number G003250A
Looking for compatibilities, I found out that the PCB G003235C is compatible.
The problem is how do I know where is the BIOS chip I need to swap.
I have attached 2 pictures for ilustration purposes.
Your help is greatly appreciated.
File comment: This is the compatible SATA PCB
File comment: This is the USB failing PCB
 Post subject: Re: Toshiba PCB swap question
PostPosted: February 2nd, 2021, 22:06
IC602 is the one, as it is the only one on the SATA PCB.
PostPosted: February 3rd, 2021, 5:58
Thanks labtech
Sometimes special situations can make you have doubts.
I'll do as you said, and report the results.
Thanks again !
PostPosted: February 3rd, 2021, 9:29
+1 labtech.
And beware when swapping Toshiba's ROM chips.
PostPosted: February 4th, 2021, 19:43
Hello unknown
Would you elaborate a bit more?
Any hidden difficulty with Toshiba's ROM chips?
TIA
PostPosted: February 4th, 2021, 19:45
If you damage the ROM chip, most people will tell you it is impossible to reconstruct its contents.
PostPosted: February 11th, 2021, 18:03
Toshiba Rom chips easilly dying when desoldering. Must be careful
Sexy Womans from your town
PostPosted: February 11th, 2021, 18:23
Is the opinion that the chips are more sensitive to heat or just that toshiba use what appears to be really high melting point solder ?
Users browsing this forum: No registered users and 241 guests
