 Post subject: WD1600AAJS-00B4A0_000500BR
PostPosted: February 22nd, 2021, 8:10
Hi all,
This HDD isn't recognized. It has spinning up then 2 or three click sounds and then the HDD is spinnning down.
From the original HDD it was possible to read the firmware (05.BRE) and only SA ID01 and ID35. I've done that with the WDMarvel Tool.
I organized a donor PCB with the same number (2060-701537-003 REVA) for the first step.
So I flashed the Firmware to the donor PCB and swap it to the bad HDD.
The drive is no spinning up and there are no click sounds. The drive is not recognized correctly but now I'am able to read 346 modules correctly.
The Permanent Overlay Modul ID11, Cache Overlay ID13, SMART & Log Current ID23 and ID0121 can't read and I get the message
"Error reading module ID11, state - DISK_ECU_UNSAFE_ERROR" for all four IDs.
So I need the Service Area Modules to load the Overlays.
WD Caviar SE
Pinnacle(Royl) Familiy
WD1600AAJS-00B4A0
Product of Thailand
Date: 07 MAR 2009
DCM: HANNHTJABN
R/N: 701537
LBA: 312581808
S/N: WCAT24817910
Please can someone help.
Thank you
 Post subject: Re: WD1600AAJS-00B4A0_000500BR
PostPosted: February 23rd, 2021, 5:02
Modules 11 and 13 you need.
Modules.zip [167.59 KiB]
Downloaded 337 times
Users browsing this forum: Cleanroom, Google Adsense [Bot] and 1308 guests
