 Post subject: 5k1000 - 7k1000
PostPosted: February 19th, 2021, 6:01
Hi
Can anybody share experience if the heads
between 5k1000-1000 and 7k1000-1000 are compatible?
thanks
 Post subject: Re: 5k1000 - 7k1000
PostPosted: February 19th, 2021, 8:15
Compatible
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: February 19th, 2021, 14:27
I would have thought that the aerodynamic design of the heads and the RPM would determine the fly height. So how can a head designed to fly at 7200 RPM work in a 5400 RPM application? Wouldn't it fly lower?
PostPosted: February 20th, 2021, 5:21
5k1000-1000 are drives that did not pass tests for 7k1000-1000. They just put new FW and run tests for 5k1000-1000.
PostPosted: February 20th, 2021, 11:07
digisupport wrote:
Compatible
Yep, done it many times :-)
PostPosted: February 21st, 2021, 2:35
Hitachi once advertised CoolSpin for 7200 RPM drives, maybe the 7K1000.c or 7K3000, that could reduce the speed to something like 4500 RPM during idle periods, but it had to be enabled through Drive Fitness Test.
PostPosted: February 24th, 2021, 15:10
You will probably find that the the heads are retracted onto the loading ramp during this time, not flying over the platters.
PostPosted: February 24th, 2021, 15:27
It's called "low power idle mode".
PostPosted: February 24th, 2021, 16:37
red bull gives you wings :D
PS interesting post
PostPosted: February 25th, 2021, 3:27
The newer HDD's use a piezocrystal to control the fly height...
PostPosted: February 25th, 2021, 16:51
As I understand it, that piezo crystal controls fine servo position. Are you referring to some other crystal?
Here is WD’s / HGST’s white paper on microactuators:
Second-generation Micro Actuator for Better Head-positioning Accuracy:
https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/collateral/tech-brief/tech-brief-western-digital-micro-actuator.pdf
Seagate refers to theirs as AcuTrac:
https://www.seagate.com/files/staticfiles/docs/pdf/whitepaper/seagate-acutrac-TP624.1-1110US.pdf
Thermal fly height control is described in this Hitachi paper:
https://web.archive.org/web/20101213153652/http://www.hgst.com/tech/techlib.nsf/techdocs/98EE13311A54CAC886257171005E0F16/$file/TFC_whitepaper041807.pdf
PostPosted: February 25th, 2021, 23:08
RPM does not determine the fly height and aerodynamic design is the same for sliders of the same generation and manufacturer.
It's common for Hitachi drives to have interchangeable heads between 5K and 7K models, not only between 5k1000 and 7k1000
PostPosted: February 26th, 2021, 13:57
... and FH is controlled by a heater element. or two.
Users browsing this forum: Google [Bot] and 243 guests
