 Post subject: HGST HDS724040ALE640 - Clear password
PostPosted: September 21st, 2021, 4:54
Hello everyone,
I hope you are able to help me out with the following.
I have a whole bunch of HDS724040ALE640 drives of which several have a USER password.
It appears that the Master password has also been changed for its no longer the default one (32 spaces or WDCWDC etc.).
I tried using ZU, but got the message that it is not supported.
1st question:
In Sediv I cant seem to find this exact model. Does anyone know if it might still work?
2nd question:
Like I said, I have several of the exact same model and firmware. Would it be possible to read out the firmware/bios to compare and see where the password is stored, and in turn be able to change it?
3rd question:
What other options are there?
Any input would be greatly appreciated!
If you need any more info, please let me know.
 Post subject: Re: HGST HDS724040ALE640 - Clear password
PostPosted: September 22nd, 2021, 7:11
An addition:
In my research I stumbled on this post:
http://www.hddoracle.com/viewtopic.php?f=21&t=3063
Here it turns out that there might actually not be a password set, but rather a drive failure.
When I remove the PCB and connect it, MHDD for example states that it still has a PW.
But I am not sure about how my HGST drives are made to know if it is the same issue as described on hddoracle or not.
Anyone have any more ideas about this?
Users browsing this forum: Majestic-12 [Bot] and 60 guests
