 Post subject: need help to understand HDD problem
PostPosted: March 10th, 2021, 1:34
Have an HDD (NTFS) with two partitions D and E.
Partition D was showing some issue.
So first, it was checked with
SeaTools.
Result:
SMART - Pass
Short Drive Self Test DST - Fail
Short Generic - Pass
Long Generic - Fail
Then:
Windows, Tools scan : No errors found
Then:
EASUS Partition Manager : No errors
Then:
Minitool Partition : NO errors, (see attachment)
Can I get advice on what exactly could be the issue considering the SeaTools DST fail and Long Generic Failure.
thanks.
p.s. am a user with not much technical knowledge
File comment: Minitool Partition analysis result
 Post subject: Re: need help to understand HDD problem
PostPosted: March 10th, 2021, 18:58
Can you show us a SMART report with a tool such as CrystalDiskInfo?
If you need your data, use a tool such as HDDSuperClone to clone your drive.
PostPosted: March 10th, 2021, 23:39
thanks.
SMART test on Seatools shows "pass"
at this point, only need to know exactly what do these tests on seatools indicate:
DST
short generic
long generic
so, if the DST and Long Generic Test show fail what exactly does it indicate.
which parts do they test and how are they different from the other tools which I indicated which do not show any errors.
thank you.
PostPosted: March 11th, 2021, 6:51
Follow exactly the indication was given to you by fzabkar.
My firmware database:
PostPosted: March 11th, 2021, 13:35
SeaTools cannot be trusted. It will tell you that a drive is OK even it has several thousand reallocated sectors.
Users browsing this forum: No registered users and 66 guests
