 Post subject: wd10jmvw-11s5xs0 Donor heads
PostPosted: March 9th, 2021, 7:42
Hi to all! :mrgreen:
wd10jmvw-11s5xs0
Sorry, please I need a donor for the heads, preferably sata, because they are easier to find.
Thanks!
Нет ничего невозможного
 Post subject: Re: wd10jmvw-11s5xs0 Donor heads
PostPosted: March 9th, 2021, 9:51
Online
That's a firebird. They are not that popular but i didn't see any problems with compatibility. FBlite didn't work as donors.
odzyskiwanie danych
PostPosted: March 9th, 2021, 10:03
Ok thanks!!
PostPosted: March 9th, 2021, 14:39
fblite works just fine in firebird. If not, then something else is wrong.
PostPosted: March 10th, 2021, 12:53
There are different slider / preamp combinations among Firebird and FBlite that are not cross-compatible.
This model often incorporates the Wafer 176.1 heads, which is confirmed by a DCM with these letters: xxxVJxx.
However, they may also use K10N heads and the DCM for those is xxxTJxx
(This is one case where the DCM on the drive provides a reliable clue about heads).
You need to find a donor with the same model and DCM digits as noted above to ensure compatibility.
http://www.datasaversllc.com
PostPosted: March 10th, 2021, 13:04
PostPosted: March 10th, 2021, 15:07
Is patiente xxxVJxx
PostPosted: March 10th, 2021, 15:08
THANK YOU ALL :idea:
PostPosted: March 11th, 2021, 18:00
ROM 0A module
DCM = | R | T J X D E D S
: : : : : : : : : unknown
: : : : : : : : top VCM
: : : : : : : ACA arm coil assembly
: : : : : : bottom VCM
: : : : : HSA type
: : : : media type
: : : preamp type
: : latch
: base
spindle motor
HSA type is essential
PostPosted: March 11th, 2021, 19:47
I try to match preamp type, dcm characters and the SPT.
PostPosted: March 12th, 2021, 12:06
I highly recommend matching the forth character from string in ROM module 0A, e.g. |N|TSRPDTM
Users browsing this forum: Google [Bot] and 114 guests
