 Post subject: Short point PCB 100696152
PostPosted: April 23rd, 2021, 6:00
Hi
Can anybody confirm me, if this is the short point for this PCB 100696152
Seagate ST500LT1012
picture in attachment
thanks
 Post subject: Re: Short point PCB 100696152
PostPosted: April 23rd, 2021, 13:26
Tip: How to identify the Read Channel test points:
http://www.hddoracle.com/viewtopic.php?f=24&t=123
PostPosted: April 23rd, 2021, 15:12
It is one of the differential lines running to the preamp. On that pcb it is the one at the middle. This pcb does not have any termination resistor on the read channel so it is not possible to differentiate between read and write channels just by looking at the traces in this case.
PostPosted: April 23rd, 2021, 15:42
True, but I would think that a voltage measurement would differentiate between read and write.
PostPosted: April 24th, 2021, 7:45
yeah, i said just by looking at the traces. I usually check it with scope if it is not trivial from the terminations, your multimeter method might be also usable, though i am not sure if all drives behave the same.
Users browsing this forum: No registered users and 53 guests
