pepe wrote:
The drive starts but gets stuck in bsy state if i removed the SSD board. However, attaching it live makes it get ready. pepe
Mine is quite the opposite. It starts without the SSD board. If i attach it live it goes BSY. If SSD board is connected from the beginning drive always BSY.
What is under the 771980 sticker on the main PCB?
Hynix H5PS5162GFR-S6C - 512Mb DDR2 SDRAM
Marvell 88SE9171 - One-Lane PCIe 2.0 to One-Port 6 Gbps SATA I/O Controller
Marvell 88i9441 - Soleil-H SATA SSHD Controller 6Gb/s SATA, Dual ARM On-Chip Processors, Encryption
WD REDFIN A11SP - Motor Combo IC
Winbond 25X40CLVIG - 4M-bit 2.5V Serial Flash Memory with uniform 4KB sectors and Dual SPI
The SSD SATA lines come out of SSD
Than go to the other side of PCB into the connector
Than to the main PCB and into Marvell 88SE9171 chip.
I could not find where the main SATA port lines go even thou i beeped all the components and pads on the pcb.
