 Post subject: Hdd hs
PostPosted: August 28th, 2021, 18:36
Hello
I need your advice, I have a WD hard drive, the heads are broken. I have 2 possibilities either I change the head or I exchange the disks. What would you advise as a solution?
Thank you
 Post subject: Re: Hdd hs
PostPosted: August 29th, 2021, 4:17
Strictly depend on respective hard drives models.
Angel Data Recovery
PostPosted: August 29th, 2021, 4:30
It depends on data ? You want to recover data or not ?
 Post subject: Objet : Hdd hs
PostPosted: August 29th, 2021, 5:53
I have exactly the same disk it's a 2,5 WD, and yes the goal is to recover the dinn
PostPosted: August 30th, 2021, 1:26
angoul
if patient drive spins OK, then just replace heads
PostPosted: August 30th, 2021, 5:44
When you say exact same disk, can you confirm DCM is same ? Swapping head it not easy if you never did it before.
PostPosted: August 30th, 2021, 10:41
it is exactly the same DCM and date
For the change of head I train so if I miss no problem
Users browsing this forum: gps31 and 78 guests
