 Post subject: Problem after secure erase
PostPosted: September 29th, 2021, 18:21
Hello all,
I found this forum googleing for info. I hope someone can help me.
I made a secure erase to a ST8000DM004 drive with gparted. It said it would take about five hours and that the drive would not report when the process finishes.
I left it working for 8 hours to be safe and then poer-off the pc.
After rebooting gparted throws an error: Input/output error during read on /dev/sda. After that it shows the drive as unallocated. If I try to create partition table I get another I/O error writing.
Fdisk does not show the unit and Windows 10 does not recognize the disk.
GsmartControl does not show any SMART errors.
Is there anything I could do to revive him or should I throw it to the bin?
 Post subject: Re: Problem after secure erase
PostPosted: September 29th, 2021, 19:40
Never mind, I found the drive was locked by password (null password in fact). It seems to work now.
I wonder why none of the above utilities warned me about it, especially gparted as it was the app that put the password on the disk.
PostPosted: September 29th, 2021, 19:46
I don't think 8 hours is long enough. That would require an average data transfer rate of 278 MB/s.
https://www.google.com/search?q=8+TB+per+8+hours+in+MB+per+second
If you examine your drive with CrystalDiskInfo, I think you'll find that it is locked with a password that was set by GParted.
Users browsing this forum: Google [Bot] and 92 guests
