 Post subject: HDD bricked after low level format was stopped
PostPosted: October 26th, 2021, 23:35
I would like to know what I can do to un-brick this HDD.
this is how I bricked it ( it was working before I did):
1- I connected it to an adaptec asr-3405 and started a low level format (I was not aware it would take so long, it is a 3TB HDD.)
2- I rebooted the PC to get out of this LLF
Now The HDD shows up in disk management without a drive letter and when i try to initialize it, it gives the 'data error cyclic redundancy check'
 Post subject: Re: HDD bricked after low level format was stopped
PostPosted: October 31st, 2021, 21:06
Plug in the drive and power up the system with the drive data disconnected--the drive might pick up where it left off and finish, so leave it on overnight and then reboot and reconnect it and try again.
PostPosted: November 1st, 2021, 10:24
The problem is resolved. I used seagate tool to reformat.
PostPosted: November 1st, 2021, 19:32
Glad you fixed it. Thank you for posting the solution. 8)
Users browsing this forum: Cyber and 84 guests
