 Post subject: WD4003FRYZ-01F0DB0 PROBLEM WITH PCB
PostPosted: July 16th, 2020, 3:12
Hello everyone,
I have this WD drive with model WD4003FRYZ-01F0DB0 and original pcb is burned.
When i install donour pcb it gives model, serial, firm and capacity on pc3k but when i enter universal utility it gives error that drive is locked.
Can someone help me with issue?
Thank you all in advance
Maestro.
 Post subject: Re: WD4003FRYZ-01F0DB0 PROBLEM WITH PCB
PostPosted: July 16th, 2020, 3:49
Sorry to ask, have you remembered to transfer ROM or firmware from burned PCB to donor ?
Your drive is most likely a Hitachi in WD disguise.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: July 16th, 2020, 4:54
This is a photo of the pcb.
Can you point me where is rom chip or which chip to transfer?
Thanx
Maestro
PostPosted: July 16th, 2020, 8:45
Yep, that's Hitachi!
My firmware database:
PostPosted: July 16th, 2020, 16:28
Did you check the fuses and TVS diodes?
There appear to be two ROMs located at the top left corner of the MCU in your photo.
PostPosted: July 17th, 2020, 14:32
Maestro wrote:
Hello everyone,
Maestro.
I bet it gives you the S/N of the donor and not the one on your bad drives label?
PostPosted: July 17th, 2020, 14:33
Bingo! :-)
PostPosted: October 29th, 2021, 13:23
Hi all,
same problem here:
need to know if this is the chip to swap on new pcb??
PostPosted: October 30th, 2021, 14:25
atamoro wrote:
Hi all,
same problem here:
no
PostPosted: October 31st, 2021, 19:06
Yes I know it. recovered data before.
PCB no 0B36131
I have transfered both chips. And worked.
That chips smaller than common Rom chips. be carefull
chek this
https://www.data-medics.com/forum/threa ... -pcb.4027/
Sexy Womans from your town
Users browsing this forum: No registered users and 69 guests
