 Post subject: Western digital PCB fried
PostPosted: November 13th, 2021, 5:59
Hi Guys,
The pcb is fried for one of the Raid drive. We have the replacement board, the question is will swap ROM will do the job. Should we get a ROM reader instead of swapping the rom, which is more safer and reliable way. Any help is most appreciated,
Many Thanks
 Post subject: Re: Western digital PCB fried
PostPosted: November 13th, 2021, 8:09
Given the level of damage there, you'll be lucky if it's just the PCB. It's always safer to make a copy of the rom, but moving them is normally a safe process for anyone with basic soldering skills. Guessing that's another victim of a modular power supply, what were the other drives in the set like ?
PostPosted: November 13th, 2021, 8:41
Other drives in the set are the same model drive, but do you think it can be more damage ? What we feel there was a short circuit on the board, because when we connected power cable melted a little.
PostPosted: November 13th, 2021, 8:53
how can I copy the rom ?
PostPosted: November 13th, 2021, 9:54
you can use an spi flash reader/programmer, but it needs to be able to adjust the supply voltage to 1.8V.
PostPosted: November 13th, 2021, 13:52
Any suggestions/recommendations for SPI flash reader/programmer?
PostPosted: November 13th, 2021, 14:40
In this disk ROM it is supplied with the voltage of 2.5V
Mikippp
PostPosted: November 13th, 2021, 19:28
yeah, indeed. Odd that other IO are 1.8V...
thx for the correction.
PostPosted: November 14th, 2021, 3:25
Given the state of the contact pads for the HSA I'd be very surprised if the preamp wasn't cooked too.
PostPosted: November 14th, 2021, 12:36
R67 is visibly damaged. This points to an overvoltage on the +5V supply. The motor controller is damaged on the 5V side as well. Therefore I believe that the preamp is most likely dead.
PostPosted: November 15th, 2021, 19:20
That looks pretty normal, not a result of the OV.
Users browsing this forum: Majestic-12 [Bot] and 85 guests
