 Post subject: WD My Password stuck in recovery process
PostPosted: November 18th, 2021, 11:30
Hello everyone,
My WD My Password (1TB, hdd) error "You Need to Format the Disk before You Can Use It". I tried to recover it with EaseUS Data Recovery Wizard, but even after 3 hours it still 0%. When I look at task manager, EaseUS Data Recovery Wizard doesn't consume any cpu and disk. Same thing (stuck at 0%) happen using Partitiond Find and Mount. I also tried using testdisk and it result with no file/folder detected. chkdsk is not an option because I my hd external becaome RAW.
Is there anything I can try ? any suggestion anyone ?
thank you.
 Post subject: Re: WD My Password stuck in recovery process
PostPosted: November 19th, 2021, 17:07
Power the drive drive and listen to it with your ear like a cell phone. Describe the sound sequence as exact as possible?
Users browsing this forum: Google [Bot] and 69 guests
