 Post subject: WDC WD30NMVW-11C3NS2
PostPosted: December 2nd, 2021, 14:46
This is a puzzler;
HDD came into lab with bent spindle and bad heads.
Performed platter transplant and new heads.
Using SATA PCB and / or Dolphin Tools USB to SATA overlay I can access SA.
FW backup was completed. Noted MOD11 was damaged (both copies) - there are other damaged modules; but none of importance.
I can upload MOD11 into RAM and HDD will ID properly. I can browse user area via utility. HDD is SED v2 so data is encrypted.
Attempted to write MOD 11 to SA; got DISK SERVO WRT FLT OFFTRACK ERROR ABA XXXXX where X is the ABA it cannot write.
I should note that MOD 02, 01, (other small modules) will read / write just fine.
Attempted to move 11 via DIR editor to working SA ABA. I've tried a bunch; always the same error (but at different ABA location).
I have even attempted to cut some modules in SA that are large enough for MOD11 (resize and edit DIR later). No success.
Finally did another heads swap; same symptom. Donor heads were tested and can R/W in 2nd donor without problems.
Any other idea's? I was thinking I could maybe upload 11 via SATA overlay board, then use special USB 3 cable (with power pins cut) and see if that will work.
 Post subject: Re: WDC WD30NMVW-11C3NS2
PostPosted: December 2nd, 2021, 15:34
This one is PebbleB, you could use sata pcb to access the data after uploading ldr i think, the decryption should be possible using donor pcb on these.
i just had an Apollo, SED, pc3k could not decrypt it, so i went for modifying the loader to have SA access while SED is on...
PostPosted: December 2nd, 2021, 15:41
pepe wrote:
so i went for modifying the loader to have SA access while SED is on...pepe
Nice work Pepe.
PostPosted: December 2nd, 2021, 15:46
Thanks pepe;
If I use SATA PCB an upload loader I cannot access any sector via ATA - I just get an abort error.
If I use utility to read, data is encrypted.
Drive ID's with proper capacity in tested. Translator can be read from SA.
MOD25/38 are both readable as well.
PostPosted: December 2nd, 2021, 16:40
that's normal for this model
There is no decryption support in pc3k for this model.
In order to get decrypted data the drive should start normally (without extra steps, like uploading a loader).
so either fix the 11, or copy encrypted data to another drive and decrypt on it, or send it to a person who has a decryptor for this model(this might be tricky, because to my knowledge only 2 people in the world can do it).
PostPosted: December 2nd, 2021, 16:44
in order to get decrypted data the drive should start normally (without extra steps, like uploading a loader).
Thanks doomer; I was aware of this - just trying to communicate I was reading something - albeit encrypted data.
Can't write loader to SA because SA is damaged, can't access data because drive is encrypted, can't use decryption USB because it's locked.
Round and round I go.
PostPosted: December 3rd, 2021, 4:42
I'd go this route.
PostPosted: December 3rd, 2021, 16:51
Thanks for everyone's suggestion.
I will start the duplication process and duplicate on it - will let you know how it works out.
Users browsing this forum: Google [Bot] and 56 guests
