 Post subject: WD140PURZ no power issue
PostPosted: January 3rd, 2022, 13:51
Hello guys!
Im faced with an issue with WD140PURZ. Looks like my friend miss SATA power module output in power supply and put SATA to PCIE. Now hard drive didnt shjow any activity like no power. I think is it possible some TVS diode died? Here is board photo, please help me to understand do i need tu loking for board or i can replace TVS? It yes where TVS on a board and models of it?)
 Post subject: Re: WD140PURZ no power issue
PostPosted: January 4th, 2022, 3:56
Diodes are top right near the power connector - also check the tiny fuses/resistors just above them.
PostPosted: January 4th, 2022, 14:03
Checked all of them. All without beep and ~200 on a multimeter:(
PostPosted: January 8th, 2022, 6:02
Not sure what you're measuring there - the fuses should have very low resistance and continuity and the diodes should have continuity and low resistance in one direction. fzabkar has a guide about protection over on hddoracle http://www.hddoracle.com/viewtopic.php?f=100&t=1615
PostPosted: January 8th, 2022, 15:10
I have already pointed out an open fuse at Tom's Hardware, but the OP hasn't replied.
Users browsing this forum: Majestic-12 [Bot] and 56 guests
