wd40efrx during a big copy had broken.. Here the sound
March 24th, 2024, 17:14
Hello guys!
My hard drive failed while I was copying files. I recorded the sound it makes when it turns on.
The BIOS hasn't been able to detect it.
I would appreciate some ideas to resolve the trouble.
Thanks for your support.
WD servomotor HDD noise.zip
HDD noise
(240.43 KiB) Downloaded 514 times
Re: wd40efrx during a big copy had broken.. Here the sound
March 27th, 2024, 0:54
I don't think it is possible just fix. Look like you have bad sectors or even slight media damage. I would start to look for new drive.
March 27th, 2024, 12:18
Swapping between 2 identical PCB, the servomotor does the same... finally We never hear the init sound... It's possible a servomotor damage ?
March 28th, 2024, 2:41
it is not servomotor sound. It is sound of moving heads
March 30th, 2024, 11:28
Ok,I will try to open hdd chase and look for stuck or lack.
Thanks for your attention.
