 Post subject: WD40NPZZ no file structure
PostPosted: March 3rd, 2022, 7:37
I receive WD40NPZZ drive
it spin ok and become ready
FW backup is OK with three error's
Any suggestion to fix problem
Thank you
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 10
Cyl Count............................... : 384
Zone allocation table................... : Ok
SA SPT.................................. : 2140
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 512 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 238 986
SA regions address...................... : by default
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA Translator loading................... : Ok
SA defects assigned..................... : 1
ROM Modules:
ROM version............................. : 01.4VP
ROM F/W version......................... : 0001004V
Overlay F/W version..................... : 01.4WP
Servo F/W version....................... : 02.7A
Heads configuration..................... : by map
Heads number in use..................... : 10
Switched off heads...................... : No
Heads map............................... : 0,1,2,3,4,5,6,7,8,9
Service area:
Power up log reading.................... : Ok
Dir data................................ : Yes
Permanent overlay....................... : Yes
CFG data................................ : No
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
CFG tech mode lock...................... : No
Self encryption drive................... : No
Master Password......................... : has not been set
User Password........................... : has not been set
UA writing.............................. : Granted
HDD resources backup
HDD info report......................... : Ok
Read ROM
Into file............................... : <HDD Profile>\Data\SABackup\ROM\ROM_01-4VP_01-4WP_02-7A.bin
Ok
Read ROM modules
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 20B............................ : Ok
Module : 30............................. : Ok
Module : 47............................. : Ok
Module : 0D............................. : Ok
Module : 4F............................. : Ok
Module : 181............................ : Ok
Reading modules
Into folder............................. : <HDD Profile>\Data\SABackup\Modules\
Module 2FF0............................. : Header error
Module 189.............................. : Header error
Module 190.............................. : Header error
Module checking 2FF0
Module checking 190 (Second level translator)
Module checking 189 (Second level translator index)
 Post subject: Re: WD40NPZZ no file structure
PostPosted: March 3rd, 2022, 8:16
SpyGlass / SpyGlass2 drive, userdata is most likely encrypted.
Read by original MCU or decrypted afterwards.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: March 3rd, 2022, 8:52
Hello digisupport,
it is sata drive from Intenso USB enclosure.
PostPosted: March 3rd, 2022, 14:10
The latest PC-3000 has a menu just for salvaging/rebuilding the level 2 translator. Try to get as much of those modules as you can using ignore error reading.
Or is it just the header error and no actual bad sectors in those modules?
PostPosted: March 3rd, 2022, 18:20
jerovsek wrote:
Hello digisupport,
Have not seen any 4 TB Intenso drives here yet. Will order one.
The sectors you are reading, do they contain any data or just zeros ?
PostPosted: March 4th, 2022, 2:15
Thank you data-medics and digisupport
I will check today.
For Intenso HDDs - in external drives or in retail boxes you can find different brands(Seagate, WD, Toshiba). No garantie, that if you buy 4TB external drive, you will find inside WD or some other brand.
PostPosted: March 4th, 2022, 2:31
I will check today.
I know, it´s like all other Intenso, shopping around.
Seen "Recertified 2 TB Rosewoods" sold as 1 TB intenso :)
PostPosted: March 7th, 2022, 2:04
I check
LBA 8 EFI
LBA 2048 NTFS
data are from LBA 960645880
head test for all heads is OK
Users browsing this forum: No registered users and 287 guests
