 Post subject: WD1600BB problem
PostPosted: March 21st, 2005, 17:18
I have a WD1600BB 160GB drive with problems. The drive is detected by the BIOS, I can read and write to the drive, MHDD does not show errors when scanning. However it is slow like hell and every few seconds the drive heads knock. Sometimes it's a few knocks within one second, sometimes there are no knocks for more than 30 seconds. Even if I don't access the drive it still knocks once in a while. Anyone has an idea what could it be. Corrupted firmware, defective drive heads? Thanks in advance for all answers.
PostPosted: March 21st, 2005, 18:28
I would doublecheck all connections…
But these drives are usually dying the same way you described…
PostPosted: March 22nd, 2005, 5:21
Thanks for your answer. Connections are fine. I actually tested the drive with abnother ATA133 cable and it behaves the same way. Yes, looks like the drive is dying :(. BTW, MHDD is a great program Dmitry. I've been using it since version 2.9 which I still prefer over the new 4.0.
PostPosted: March 22nd, 2005, 10:45
Try to use newest snapshots (4.1.9) — it has no activation, has SCSI support, ATA terminal ;)
You can get snapshots here: http://hddfiles.zirochka.com/
(just place the .exe over your 2.9 file)
Docs will come with release, so for now F1 should work enough.
PostPosted: March 22nd, 2005, 12:11
Thanks, I'll check it right away. BTW my Antivir is blocking access to files hfr2.0setup.exe and hsr2.0setup.exe from this archive saying that it's "the Trojan horse TR/Spy.KStaff". Any idea why is that happening...
PostPosted: March 22nd, 2005, 15:17
Just checked with symantec. Nothing found.
PostPosted: March 22nd, 2005, 16:00
Looks like the german Antivir personal edition is giving false alarms though :). That's what I'm using : http://www.free-av.com/.
Users browsing this forum: Google [Bot] and 77 guests
