 Post subject: Simply change pcb between two WD3200JD-22klb0?
PostPosted: November 10th, 2021, 16:05
Hi all.
my wd3200JD-22klb0 went dead about power supply ( number 1 in photo)
I ask to you if it works to simply change the pcb with same model in photo 2 just to rescue my data
they has :
_same number model
_same drive parameters (LBA ecc…)
_same pcb number
_other?
_different place of production
_differentt pcb number sticker
_different dcm number about latch and bottom vcm
DSBACAJCH vs DSCHCAJCH
example of DCM: HSEHYV2AH
1- Motor (H)
2- Base (S)
3- Latch (E)
4- Bottom VCM (H)
5- Media (Y)
6- Headstack (V)
7- Actuator-Preamp (2)
8- Top VCM (A)
9- Separator (H)
_other ?
thanks in advance for your help
byeImage
 Post subject: Re: Simply change pcb between two WD3200JD-22klb0?
PostPosted: November 11th, 2021, 10:55
You will need to swap the bios of the faulty drive to the donor board.
Slim Farza
Arobas Uldry Tunis
I.T. support and data recovery.
http://tunis.ausarl.ch
PostPosted: November 11th, 2021, 12:01
the question is wether preamp survived. Needs checking, otherwise it can kill data.
PostPosted: November 11th, 2021, 14:04
Show us the other side of the PCB. Then we'll know if the 12V or 5V side of PCB was damaged. I can also show you the preamp test points.
PostPosted: November 14th, 2021, 13:25
Hi.
here the ohter side
so anyway I have to swap thwe bios?no possibilty an only change pcb?
thanks
PostPosted: November 15th, 2021, 19:23
MCU is toast, so likely the preamp as well. Still worth checking, but treat as likely failed.
PostPosted: November 16th, 2021, 17:23
Hi.do You mean That all data are lost?
What could i do?
PostPosted: April 27th, 2022, 10:39
Hi All
sorry for the wait
For now I've only put the good pcb on my disk: the disk starts but the pc doesn't recognize it...
Do you think it's a good news about preamp?
Can I go on to try to swap the bios of the faulty drive to the donor board?If yes can you show me where is on the board the bios?
thanks
PostPosted: April 27th, 2022, 13:30
U12
PostPosted: April 27th, 2022, 17:46
you could record the sound and post it here...
PostPosted: May 2nd, 2022, 4:46
Lardman wrote:
U12
thank you.
Both disk are under swap operation.... :)
I'm waiting the Call
PostPosted: May 2nd, 2022, 4:52
HI pepe
I don't have with me the disk( it's under U12 swap) but once plugged with other board it makes no strange noise ( based on my humble knowledge... )
thanks
see you soon
PostPosted: May 16th, 2022, 13:16
HI all
All works after u12 swap.
no bad sounds/other. :mrgreen: :mrgreen: 8) :druunk: :agree:
All data/files are present.
thank you all
PostPosted: May 17th, 2022, 2:06
morning
hdd status :!:
PostPosted: May 17th, 2022, 3:41
Please you were able to sort it. It's a good idea now to plan a good backup policy so you won't need to worry about recovery the next time.
Users browsing this forum: No registered users and 58 guests
