 Post subject: Microsoft Surface Pro Bitlocker Recovery.
PostPosted: April 8th, 2022, 8:06
Hi Friends
I have got a case of microsoft surface pro bitlocker recovery (Surface pro model 1866) . Suddenly it is showing bitlocker encryption. Customer says he is not aware of what is bitlocker.
Chances are that customers IT dept has previously enabled bitlocker.
Manage-bde shows TPM+numerical key and key as protectors. Customer is not having microsoft account so microsoft was unable to help.
Is there anything I can try. I think this is embedded type device and not a laptop.
I tried to boot from winpe which shows 2 partitions but it does not show Bitlocker related information.
I have disabled secure bot from bios . I will try to clone 500GB SSD into SATA SSD so that further process can be done safely.
(internal storage is embedded and directly soldered ).I am going to give it a try using hddsuperclone .
What should I do in this case. Any expert guideline will help .
 Post subject: Re: Microsoft Surface Pro Bitlocker Recovery.
PostPosted: April 8th, 2022, 11:18
If you don't have keys there's no way to access data. I've been using BGA adapter, works great but you still need the keys.
PostPosted: April 9th, 2022, 1:23
Hi suricate.ch
Thanks for replying. Yes you are right I might succeed in imaging disk which will be of no use without recovery key /password.
Protectors here is TPM as well but again its of no use as we can't read TPM directly.
Users browsing this forum: Google [Bot], Hardcore Games and 83 guests
