 Post subject: WD HC550 16-18 Tb new firmware and windows update tool
PostPosted: April 27th, 2022, 15:19
Hello friends,
After mailing WD for one week i got latest firmware and hugo tools. I updated mine to latest version even newer from site. Mine was WD 16 TB HC550. Good Luck
https://mega.nz/file/KpIS0B7a#iObN7uRq_ ... aIxYIk6Dyk
Results: Less clicking and head sound.
How to update: Install Hugo inside zip file and run it from its directory as administrator and Hugo runs at cmd screen press s and enter note serial number of WD HC550
then
u -f /path/to/file/<firmware_file_name> -s (HDD serial) and enter wait 20 secs may be. Update finishes. Shutdown pc and restart. New firmware is intalled.
Good Luck.
 Post subject: Re: WD HC550 16-18 Tb new firmware and windows update tool
PostPosted: April 27th, 2022, 18:12
Many thanks.
PostPosted: April 28th, 2022, 5:54
Thank you
PostPosted: April 28th, 2022, 13:04
You can get firmwares at https://support-en.westerndigital.com/a ... a_id/29514
Try these firmwares but take care for Sata or SAS
PostPosted: April 29th, 2022, 11:23
safakhan, Nope, this firmwares for something customized drives, letters "GA" says it, and its not compatible with drives that you can buy in local shop. Your fw PCGNW680 is for standard generic drive letters "GN" says it. It would be good to find PCGNC680
PostPosted: April 29th, 2022, 14:26
I uploaded one worked like a charm and for my second drive installed from site firmware.
PostPosted: April 29th, 2022, 17:13
How did you decide which firmware version was appropriate?
PostPosted: April 29th, 2022, 22:50
fzabkar, Just look what firmware already installed, and choose update with same letters, only three last symbols in name tells version
PostPosted: May 1st, 2022, 15:44
These are the headers of the CODF modules.
00000000  68 E0 0E 00 82 00 00 00 43 4F 44 46 D2 17 EA 46  hà..‚...CODFÒ.êF
00000010  00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00  .. .............
00000020  08 00 00 00 00 00 00 00 00 01 00 00 22 E9 FD 8C  ............"éýŒ
00000030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000040  01 14 00 00 57 32 33 32 30 30 30 57 32 33 32 00  ....W232000W232.
00000050  30 37 2F 32 37 2F 32 30 20 31 37 3A 30 37 3A 34  07/27/20 17:07:4
00000060  37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  7...............
00000070  50 43 47 41 57 32 33 32 00 00 00 00 00 00 00 00  PCGAW232........
00000080  50 43 4D 00 00 00 00 00 50 4C 41 49 4E 5F 53 41  PCM.....PLAIN_SA
00000090  52 45 4C 45 41 53 45 00 62 6C 64 63 72 65 77 00  RELEASE.bldcrew.
000000A0  00 00 00 00 66 6F 72 67 65 73 6C 61 76 65 30 32  ....forgeslave02
000000B0  00 00 00 00 2F 6D 6E 74 2F 79 2F 63 63 62 38 2F  ..../mnt/y/ccb8/
000000C0  52 32 33 32 2F 6C 69 62 72 61 72 79 2F 50 43 4D  R232/library/PCM
000000D0  00 00 00 00 50 43 47 41 57 32 33 32 00 00 00 00  ....PCGAW232....
000000E0  00 00 00 00 00 00 00 00 00 00 00 00 2A 93 7D 3C  ............*“}<
000000F0  28 13 01 02 F8 FF FF FF 42 00 00 00 30 30 30 30  (...øÿÿÿB...0000
00000100  30 30 30 30 30 30 30 30 30 30 30 00 66 61 38 36  00000000000.fa86
00000110  64 37 63 35 63 35 34 62 64 61 31 4D 9A 5B 6B 58  d7c5c54bda1Mš[kX
00000000  F4 A4 0E 00 82 00 00 00 43 4F 44 46 3C 0F 52 D9  ô¤..‚...CODF<.RÙ
00000020  08 00 00 00 00 00 00 00 00 01 00 00 62 07 2E 8E  ............b..Ž
00000040  04 02 00 00 43 32 33 32 30 30 30 43 32 33 32 00  ....C232000C232.
00000050  30 37 2F 32 37 2F 32 30 20 31 37 3A 30 38 3A 30  07/27/20 17:08:0
00000060  33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  3...............
00000070  50 43 47 43 43 32 33 32 00 00 00 00 00 00 00 00  PCGCC232........
00000080  50 43 4D 00 00 00 00 00 45 4E 43 5F 44 49 53 5F  PCM.....ENC_DIS_
000000D0  00 00 00 00 50 43 47 43 43 32 33 32 00 00 00 00  ....PCGCC232....
000000E0  00 00 00 00 00 00 00 00 00 00 00 00 28 C9 90 19  ............(É..
000000F0  28 13 01 01 F8 FF FF FF 42 00 00 00 30 30 30 30  (...øÿÿÿB...0000
00000110  64 37 63 35 63 35 34 62 64 61 31 4D 05 CB B8 3E  d7c5c54bda1M.˸>
00000000  CC 2B 0F 00 82 00 00 00 43 4F 44 46 10 A7 A0 A6  Ì+..‚...CODF.§ ¦
00000020  08 00 00 00 00 00 00 00 00 01 00 00 FB DA 41 FE  ............ûÚAþ
00000040  01 02 00 00 57 36 38 30 30 30 30 57 36 38 30 00  ....W680000W680.
00000050  30 39 2F 32 38 2F 32 31 20 31 33 3A 35 38 3A 33  09/28/21 13:58:3
00000060  31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  1...............
00000070  50 43 47 4E 57 36 38 30 00 00 00 00 00 00 00 00  PCGNW680........
000000A0  00 00 00 00 66 6F 72 67 65 63 63 62 00 00 00 00  ....forgeccb....
000000C0  52 36 38 30 2F 6C 69 62 72 61 72 79 2F 50 43 4D  R680/library/PCM
000000D0  00 00 00 00 50 43 47 4E 57 36 38 30 00 00 00 00  ....PCGNW680....
000000E0  00 00 00 00 00 00 00 00 00 00 00 00 4C 4E DD 30  ............LNÝ0
00000100  30 30 30 30 30 30 30 30 30 30 30 00 62 63 61 66  00000000000.bcaf
00000110  38 62 32 37 33 63 62 66 64 64 35 4D 51 9B FB 8A  8b273cbfdd5MQ›ûŠ
PostPosted: May 3rd, 2022, 0:01
Here PCGNC680 for generic models http://files.hddguru.com/download/Firmw ... GNC680.zip
PostPosted: May 3rd, 2022, 0:04
napalm_atx wrote:
That's SAS firmware, isn't it?
PostPosted: May 3rd, 2022, 2:44
fzabkar, Yes, in name PC means series, in this case Paris-C, GN means generic, C means SAS ISE drive
PostPosted: August 2nd, 2022, 8:58
napalm_atx wrote:
Where did you get those firmware files? It not post in WD page.. I wanna find a HC530 firmware file, But those they post in WD page's firmware files seem like for Specific model that you can't buy in normal store
PostPosted: August 2nd, 2022, 9:04
napalm_atx wrote:
Could you get me a HC530 firmware start with letter "LDGNW"'s latest firmware? Please? I don't know where to find it.
PostPosted: August 2nd, 2022, 22:12
From WD support
Here http://files.hddguru.com/download/Firmw ... GNW2L0.zip
PostPosted: August 5th, 2022, 11:10
napalm_atx wrote:
From WD support
Could you share WD support's link? I mean the link direct to LDGNW's download page. I do not wanna download this firmware next time still bother you. By the way, thank you for upload LDGNW2L0.zip for me! amazing!
PostPosted: August 7th, 2022, 22:15
Sead, There's no direct link, WD support talking directly via e-mail. I already upload all updaters that i have here http://files.hddguru.com/download/Firmware%20updates/ and here ftp://atxlab.ddns.net/ftp/hdd/fw/
PostPosted: August 10th, 2022, 22:50
Latest fw for HUS728T8TALE6L4 https://we.tl/t-sxrYxPo4h8 i also upload it here ftp://atxlab.ddns.net/ftp/hdd/fw/hgst/ and wdckit ftp://atxlab.ddns.net/ftp/hdd/wd/wdckit/
PostPosted: August 11th, 2022, 14:51
Thank you !
PostPosted: August 26th, 2022, 1:07
New firmware PQGNW540 for WUH722020ALE6L4 http://files.hddguru.com/download/Firmw ... GNW540.zip 6.3MiB size :shock:
Users browsing this forum: Google [Bot] and 48 guests
