 Post subject: ST4000LM024
PostPosted: May 1st, 2022, 21:27
Hello
Drive in topic came clicking and needs heads replacement.
After heads changed I was able to image approximately first 200GB.
The drive now come ready but no UA access and the ata registers failed when trying to enter the seagate utility.
Terminal shows :
SIM_Readydiskfile failure1:
ErrorCode: 0x00001002
SIM_Readydiskfile read again
SIM_Readydiskfile failure2:
DSC PASS
(P) SATA Reset
Any suggestions would be appreciated
 Post subject: Re: ST4000LM024
PostPosted: May 1st, 2022, 22:40
0x1002: Memory Miscompare Error
PostPosted: May 1st, 2022, 22:49
Thanks for your input.
Is it related to MC?
PostPosted: May 1st, 2022, 22:56
heads cannot read sysfile so either bad heads or surface defects.
PostPosted: May 5th, 2022, 6:30
Can you share or PM the Error List you have access too .
PostPosted: May 5th, 2022, 6:32
unknown wrote:
Hello
Terminal shows :
DSC PASS
(P) SATA Reset
Well,
It was cloning @ 200GB right why did you stop the process ,You should have let it run by changing cloning parameters in such a way that drive would skip errors
PostPosted: May 7th, 2022, 9:42
Case solved ( HM edited to start from H1 )
Thanks all for your inputs.
PostPosted: October 23rd, 2023, 14:45
Can someone explain how to do this procedure? I have the same issue.
Users browsing this forum: Google [Bot] and 93 guests
