 Post subject: Seagate Barracuda ST31000528AS 7200.12 1TB HDD
PostPosted: May 5th, 2022, 9:06
I'm new here and would like some advice before I do anything dumb.
My NAS drive was hacked back in February and everything was locked with deadbolt ransomware. This in itself was not an issue as I had everything backed up on another drive, and/or still stored on laptops etc.
I recovered most of what I needed from an external Iomega HDD. I came back to this a day later to finish recovering the data, but found the drive was no longer visible in Windows (Win10). Windows beeps to acknowledge that something had been connected, but no drive appears. I checked in Disk Management, and can see the drive, but it shows as 'Unknown' and 'Not Initialized'. I've tried connecting to different machines, but always the same.
I opened the Iomega unit and found that it's running a Seagate Barracuda ST31000528AS 7200.12 1TB HDD. Google suggests these have a number of common 'issues', and I ended up on this forum.
I'm reasonably tech savvy and quite proficient with electronics. I do have a USB to TTL adapter and the ability to connect directly to the HDD, but don't know how best to proceed. I've re-flashed BIOS chips on laptops before, but never worked on a failed HDD.
When the drive is powered up, it spins up as normal and doesn't make any odd noises or clicks. You can hear a second or two of normal disk access noise when you first power it up, but quiet after that. I think the drive keeps spinning until the power is removed. I've tried a variety of Windows based recovery software, but nothing works because the drive isn't visible in Windows. DMDE is the only one that can actually see the drive, but can't do anything with it. It's listed as 'Disk 2 - 2.2 TB - USB - Iomega Iomega: 1.f: FF310005280000000000'. If I try to scan the disk, I get 'LBA: 0 (try 1): SCSI I/O Error'.
Hopefully that's enough to get started. It's not the absolute end of the world if I can't recover the remaining data (mostly photos), but I'd REALLY like to recover them if I can. Would consider paid options (UK Based) if there's nothing I can do myself.
Any assistance would be great.
Thanks for reading,
Ian.
 Post subject: Re: Seagate Barracuda ST31000528AS 7200.12 1TB HDD
PostPosted: May 6th, 2022, 3:02
Hi Ian
You have two options here:
1. Consult a Data Recovery professional and get your data recovered. At this point, and based on your description, chances are it shouldn't be too expensive. But that's just a guess at this point. I suggest Sean at pcimage.co.uk .
2. Take the DIY route accepting the risk of losing everything along the way. In that case, remove your drive from the Iomega box and connect it directly via SATA to a PC. Connect the USB to TTL and get a terminal output. Post it here. This will help diagnose the drive. To recover your data, run linux, download HDDSuperClone tool and image your drive onto a new one. Then, recover data from the clone using software like DMDE or UFS. If you have any questions about each of these steps, specify.
As always, your safest way is option 1., but it's your data = your choice.
Best of luck.
PostPosted: May 6th, 2022, 3:26
northwind wrote:
... remove your drive from the Iomega box and connect it directly via SATA to a PC.
I'd certainly try that first. If that doesn't give you access don't just drop it into your local pc repair place to play with use a proper recovery professional.
PostPosted: May 6th, 2022, 5:12
Thanks guys.
I don't have easy access to a tower PC to attach the drive directly to SATA. I'm laptop only these days. I guess I could possibly pop it in my CAD workstation at work.
I've got a spare ATX power supply and USB to TTL converter setup at home. I tested with a similar Seagate drive last night, and I get output on a PuTTy terminal. I guess there's little risk in seeing what output I get, as long as I don't try and change anything.
Are there any particular commands that I should run, or will it show errors as soon as it connects?
Thanks,
Ian.
PostPosted: May 6th, 2022, 5:50
You'll get out immediately after powering the drive (reconnecting the power after establishing serial connection is needed). Sometimes this may indicate and error.
Obviously you want to be very careful about entering commands but you should be safe with read commands like ctrl + z,ctrl + a , ctrl + I ctrl + L. If you haven't already checked the smart values /1 N5
PostPosted: May 6th, 2022, 6:38
Excellent. I’ll hook it up this evening and report back with my findings.
Thanks,
Ian.
PostPosted: May 6th, 2022, 17:04
Right then..
Here's the output from the read commands you listed before. I'm guessing the smart values probably shouldn't all be zero. No idea if the registers are good or bad.
ctrl + a
F3 T>
Package Version: PH0G7B.CCD4.CT0C2H., Package P/N: 100597862, Package Builder ID: AT,
Package Build Date: 10/21/2009, Package Build Time: 14:16:11, Package CFW Version: PH0G.CCD4.00215571.AT00,
Package SFW1 Version: B74D, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 10211416, CustomerRel: CC44, Changelist: 00215571, ProdType: PH0G.CCD4, Date: 10/21/2009, Time: 141611, UserId: 00236537
Servo FW Rev: B74D
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A2 07 03 03
ctrl + I
F3 T>
YetiST Rev: 649B; No Host; SpdLimit: No; SSC: Yes; LED: No; StagSpinByp: Yes;
SATA Block Registers
ATA
400A0000: 0000 0000 0000 0000 0000 0000 0000 0000
400A0010: 0000 0000 0000 0080 0040 0000 0000 0400
400A0020: 0080 0000 0010 0210 0100 0100 0000 0000
400A0030: 0000 841B 0000 0000 0000 0000 0000 0000
400A0040: 0000 0000 0000 0000 0000 0000 0000 0000
400A0050: 0000 0000 4795 57A5 CE2D 0000 0000 0000
400A0060: 0001 0000 0000 0000 0000 0000 0000 0000
400A0070: 0000 0001 0000 0000 0000 0000 0000 0000
400A0080: 0000 0000 0001 0001 0000 0000 0000 0000
400A0090: 0001 0000 0000 0000 0000 0000 0000 0000
400A00A0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00D0: FFFF FFFF FFFF FFFF 0000 0000 0000 0000
400A00E0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00F0: 0000 0000 0000 0000 0000 0000 0000 0003
SATA Global
400A0100: 0000 0000 0000
Link Layer
400A0130: 0000 0000 0000 0000 8000 0000 0F00 0000
400A0140: 0020 0000 0000 0000 0000 0000 0000 0101
400A0150: 0000 0000 0000 0000 0000 0000 0000 0000
400A0160: 0000 0000 0000 0000 0000 0000 0000 0000
400A0170: 0000 0000 0000 0000 0000 0000 0000 0000
400A0180: 0000 0000 0000 0000 0000 0000 0000 0000
400A0190: 0000 0000 0000 0000 0000 0000 0000 0000
400A01A0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01D0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01E0: 0000 0000 0000 5032 5232 5032 5232 0000
400A01F0: 0000 0000 0000 0000 0000 0000 0000 0D00
Transport Layer
400A0250: xxxx xxxx xxxx xxxx xxxx xxxx 0000 000F
400A0260: 0000 0000 7FF7 7F9D 0000 0020 0000 3018
400A0270: 0000 0000 0000 0000 0000 0000 0000 0000
400A0280: 0000 0000 0000 0000 0000 0000 0000 0000
400A0290: 0000 0000
NCQ Cmd Validation
400A0300: 0000 0000 0000 0000 0000 0001 0000 0000
Application Layer
400A0390: xxxx xxxx xxxx xxxx 0000 0000 0000 5058
Shadow Task File
400A03A0: xxxx xxxx 0000 0000 0000 0000 0000 0000
400A03B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03D0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03E0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03F0: 0000 0000 0000 0000
PhyPM Regs
400A0700: 0000 000F 0000 0000 0010 0000 0000 0000
400A0710: 0000 0000 0000 0000 0000 0000 0000 0000
400A0720: FFFF FFFF FFFF FFFF 0000
Physical Layer
400A0800: 0000 0000 0001 0000 0000 0000 0000 0020
400A0810: 0000 0001 0000 005D 2CC0 C9C5 9000 3333
400A0820: 364D A494 0800 96A8 1010 0004 0000 0000
400A0830: 0000 0406 0000 0000 0000 0000 0000 0000
400A0840: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
400A0850: 0000 0000 0000 0000 0000 0000 0000 0000
400A0860: 0000 0000 0000 0000 0000 0000 0000 0000
400A0870: 0000 0000 0000 0000 0000 0000 0000 0000
400A0880: 0000 0000 0000 0000 0000 0000 0000 0000
400A0890: 0000 0000 0000 0000 0000 0000 0000 0000
400A08A0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08D0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08E0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08F0: 0000 0000 0000 0000 0000 7878 7878 0000
Diagnostic Mux
SATA Visibility Mux
400A02E0: xxxx xxxx xxxx xxxx xxxx xxxx 0000 0000
400A02F0: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Layers Diag Mux
400A0EF0: xxxx xxxx xxxx xxxx xxxx xxxx 0000 0000
400A0F00: 0007 0000 0000 0000 0000 0000
Shanghai390 Phy Registers
TX
8000: 10 00 00 25 01 03 01 00 00 04 00 00 07 FF 07 80
8010: 00
RX
8600: 00 00 00 65 40 18 00 24 30 02 14 00 10 00 A0 10
8610: 00 00 00 00 00 0C B1 82 D4 FC A8 00 00 00 01 7C
8620: 83 FF 40 00 05 00 00 05 00 00 00
MCTL
8700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8710: 01 00 00 00 00 00 00 00 00 00 00
AFE
8800: 18 05 08 00 00 13 04 0F 09 08 00 00 30 18 0A 00
8810: 18 05 00 01
SIF
C000: 08 00 00 00 09 00 07
Wrapper
C100: 02 00 C7 00 00 67 00 00 00 04
PatGen
D000: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D010: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
D020: 55 55 55 55
CMU
F000: 73 24 00 2E 0E 00 85 36 36 00 F4 39 0C 50 64 01
F010: 01 00 17 00 00 7F 1C 20 00 00 3D 19 19 00
VBM Cache Search Registers
40012680: 0000 0000 0000 0000 007F 0000 0000 00FF
40012690: 0000 0000 0000 0000 0000 0000 0000 0000
Traverser Regs
40012700: 0000 0000 0000
Host Data Manager Regs Bank 0
40012800: 0007 0000 7FFF 0000 0000 0000 0000 0000
40012810: 0000 0000 0000 0000 0000 0000 0000 0000
Disc Data Manager Registers Bank 0
40012900: 0DC7 0180 0200 0000 0200 0000 0200 0000
40012910: 0200 0000 0200 0000 0200 0000 0200 0000
PBM Memory Controller Registers
40012A00: 0090 000B 0008 0235 0033 4002 0029 4423
40012A10: 00A2 E400 E400 0090 0090 0000 0000 0000
40012A20: 0000 0000 0000 0000 0000 0000 0000 0000
40012A30: FFFF 07FF 0000 0000 FFFF 07FF 0000 0000
40012A40: FFFF 07FF 0000 0000 FFFF 07FF 0000 0000
40012A50: 0000 0000 6B82 0500 B026 9004 0DC8 300A
40012A60: 0000 0000 0000 0000 0000 0000 0000 0000
40012A70: 0000 0000 0025 0000 0000 0000 0000 0000
FDE Block
40012B00: 0000 0000 0000 0000 0000 0000 0000 0000
40012B10: 0000 0000 0000 0000 0000 0000 0000 0000
40012B20: 0200 20F0 7E82 90F5 0147 490E 0000 0000
40012B30: 0000 0000 0000 0000 0000 0000 0000 0000
Hardware Phy Event Counters
00000000: 0000 0000 0000 0000 0000 0000 0000 0000
00000010: 0000 0000 0000 0000 0000 0000
R_ERR on RX FIS Non-data: 00000, Data: 00000
R_ERR on TX FIS Non-data: 00000, Data: 00000
ctrl + L
F3 T>
New Skews Pharaoh 0F with VTPI,RAP16,Common Code 4
Product FamilyId: 3F, MemberId: 03
HDA SN: 5VP4BK74, RPM: 7201, Wedges: 120, Heads: 4, Lbas: 74706DB0, PreampType: 71 03
PCBA SN: 0000E029LVVD, Controller: YETIST_3_0(649B)(3-12-3-3), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 91, BufferBytes: 2000000
Servo FW Rev: B74D
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 compiled off
/1 N5
F3 1>N5
Att
Num Flgs normlzd worst raw
0 0000 0 0 00000000000000
PostPosted: May 6th, 2022, 17:47
What does the drive log show when it is initially power up. Not return smart isn't a good sign.
PostPosted: May 6th, 2022, 18:02
Not very much from memory. I think it just says Rst X20M or something similar. I’ll check in the morning and post the exact message.
PostPosted: May 7th, 2022, 4:06
Send Ctrl+X as well.
And
T> V1
and
T> V40
PostPosted: May 7th, 2022, 4:23
On power up, all I get is Rst 0x20M
ctrl + Z gets me to the F3 >T prompt.
V1 gets me this:
F3 T>V1
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 4 0
Head 0: entries 1 slips 0
Head 1: entries 0 slips 0
Head 2: entries 0 slips 0
Head 3: entries 0 slips 0
Total Entries 1 Total Slips 0
V40 gets me this:
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
PBA Len Flags Phy Cyl Hd PhySctr SFI
PostPosted: May 7th, 2022, 4:37
Just realised I didn’t do Ctrl X. Hang on a few mins.
PostPosted: May 7th, 2022, 4:40
You should get something more - you may need to leave it a while, or spin it down and then up again. I don't want to randomly start suggesting commands.
Unless I've missed something, nothing you've posted so far would suggest the drive is actually reading from the platters.
PostPosted: May 7th, 2022, 4:46
Here's ctrl X
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
4294967295 99999999 0 FF FFFFFFFF FFFFFFFF FF FFFFFFFF
4294967295 0 0 FF FFFFFFFF FFFFFFFF FF FFFFFFFF
1174 1175 5868 2F 000000 000000 1 00000080 SPN_UP NORMAL
7042 5868 23 34 000000 000000 1 00000080 TCC 0
7065 23 16 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000000 L 00000004 BO 000000 BES 00E9C76.00E9E75.00E9C76
7083 18 7 02 002241 000000 1 00000080 XFR RD SYS LBA B 0001D682 L 00000001 BO 000000 BES 009B2E5.009B364.009B2E5
7542 459 14 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000006 L 00000010 BO 000000 BES 00C17F6.00C1FF5.00C17F6
7556 14 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 0000001A L 000000CA BO 000000 BES 00C17F6.00C7CF5.00C17F6
7568 12 6 02 002241 000000 1 00000080 XFR RD SYS LBA B 000055EE L 00000001 BO 000000 BES 006EE00.006EE7F.006EE00
7574 6 8 02 002241 000000 1 00000080 XFR RD SYS LBA B 000055D6 L 00000018 BO 000000 BES 00C17F6.05FFFFF.00C17F6
7584 10 3 02 002241 000000 1 00000080 XFR RD SYS LBA B 000061B7 L 00000008 BO 000000 BES 006D880.006DD7F.006D880
7589 5 6 02 005041 000000 1 00000080 XFR SYS LBA B 000061B7 L 00000001 BO 000000 BES 006D880.006D8FF.006D880
7595 6 8 02 005041 000000 1 00000080 XFR SYS LBA B 0002BBC7 L 00000001 BO 000000 BES 006D880.006D8FF.006D880
7604 9 263 02 002241 000000 2 C4090082 XFR RD SYS LBA B 000045F5 L 00000494 BO 000000 BES 009BAE5.00C04E4.009BAE5
7867 263 2273 02 002241 000000 2 43110081 XFR RD SYS LBA B 000045F5 L 00000001 BO 000000 BES 009BAE5.00C04E4.009BAE5
10165 2298 259 02 002241 000000 2 43110081 XFR RD SYS LBA B 0002A005 L 00000494 BO 000000 BES 009BAE5.00C04E4.009BAE5
10424 259 648 02 002241 000000 0 8980009F XFR RD SYS LBA B 0002A085 L 00000001 BO 000000 BES 009BAE5.00C04E4.009FAE5
11072 648 342 02 002241 000000 2 C3160080 XFR RD SYS LBA B 0002A086 L 00000413 BO 000000 BES 009BAE5.00C04E4.009FB65
11414 342 2174 02 002241 000000 2 43110081 XFR RD SYS LBA B 0002A086 L 00000001 BO 000000 BES 009BAE5.00C04E4.009FB65
13624 2210 253 02 002241 000000 2 43110081 XFR RD SYS LBA B 00008A0C L 000000C8 BO 000000 BES 006210D.006850C.006210D
13877 253 2323 02 002241 000000 2 43110081 XFR RD SYS LBA B 00008AC1 L 00000001 BO 000000 BES 006210D.006850C.0067B8D
16200 2323 266 02 002241 000000 2 43110081 XFR RD SYS LBA B 0002E41C L 000000C8 BO 000000 BES 006210D.006850C.006210D
16466 266 2307 02 002241 000000 2 43110081 XFR RD SYS LBA B 0002E4CD L 00000001 BO 000000 BES 006210D.006850C.006798D
18773 2307 4 02 005041 000000 1 00000080 XFR SYS LBA B 000075AA L 00000001 BO 000000 BES 0061B0D.0061B8C.0061B0D
18778 5 8 02 005041 000000 1 00000080 XFR SYS LBA B 0002CFBA L 00000001 BO 000000 BES 0061B0D.0061B8C.0061B0D
18788 10 0 47 000000 000000 1 00000080 DISC_SLIP
18788 0 8 02 005041 000000 1 00000080 XFR SYS LBA B 000055B4 L 00000008 BO 000000 BES 0061C8D.006208C.0061C8D
18797 9 8 02 005041 000000 1 00000080 XFR SYS LBA B 0002AFC4 L 00000008 BO 000000 BES 0061C8D.006208C.0061C8D
PostPosted: May 7th, 2022, 5:01
I've left it for several minutes with 0x20M on the screen. Nothing seems to happen until I hit it with ctrl Z.
I used ctrl C to spin down/up etc and get a similar response.
ASCII Diag mode
F3 T>
Spinning Down
Spin Down Complete
Elapsed Time 10.526 secs
Delaying 5000 msec
Jumping to Power On Reset▒
Rst 0x20M
ASCII Diag mode
When it gets to 'Rst 0x20M' after the Power On Reset, it just sits there again. Ctrl Z getting me back to the ASCII Diag mode prompt.
Not sure the relevance of the funny character after 'Jumping to Power On Reset', but that's what came up.
Do I need to wait longer to see if anything comes up after power on, or should it show something within a couple of minutes?
PostPosted: May 9th, 2022, 3:28
Your drive has reported damaged sysfiles and the translator isn't loading.
I think it's time to get advise from a pro in your area.
Alternatively, you can keep going the DIY path, but things can get nasty.
PM me if you need more info.
PostPosted: May 9th, 2022, 5:42
I left it for a reason - even though as you know I'm strong supporter of DIY.
PostPosted: May 9th, 2022, 6:29
Thanks Guys.
I'm in agreement. I'll get in touch with Sean @ pcimage before we potentially make things worse.
Ian.
PostPosted: May 9th, 2022, 9:52
Ianh wrote:
Thanks Guys.
Ian.
Ian ,
These drives have a issue thats common in these drives ,If the drive is not clicking then its a good chance sean can recover the firmware issue and clone the hdd to a working hdd and get to your data ,BTW assuming you manage to solve the firmware issue you still have to clone the hdd ,BTW even for cloning you can get lots of data with HDDSuperclone ,Anyway if they are in seans hands they are in safe hands ,You can also contact andy watson my friend
PostPosted: May 9th, 2022, 13:35
Thanks. It’s all booked in with Sean now. Hopefully some good news next week.
Ian.
Users browsing this forum: Google [Bot] and 49 guests
