 Post subject: ST1000LM035 - MC-Issue - can't write sysfile back
PostPosted: November 30th, 2020, 15:17
Dear friends,
i'm working on a Seagate ST1000LM035-1RK172 SBM3 with probably MC-Issue.
Drive wasn't detected. After unlocking patch in PC3K i got following messages without Ctrl-Z:
Boot 0x80M
Tech Unlock Handshake: 0xFE0E82EA
Reply:
QB
Rst 0x80MSrv DETCR init 0x0000
Update Capacity and Save
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 000013C0 At SU: 0006BEA0 NT: 0000001E OT: 000001E0
(POR) Recover Secondary MCMT Opened Recovered
Starting LBA of RW Request=0006FC8C18 Length=00000534
ProcessRWError -Read- at LBA 0006FC8C21 Sense Code=43110081Out:
AttemptAutoReal-61A80
ERC TO exceeded, orig value in us:FFFFFFFF
MS Read Fails: 37E460C0,000029A0
(MC POR Duration): 0000000246
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
Starting LBA of RW Request=0006FC6F7A Length=00001DEB
ProcessRWError -Read- at LBA 0006FC6F7C Sense Code=43110081Out:
FAILED to spare00000101!
ProcessRWError -Read- at LBA 0006FC6FBC Sense Code=43110081Out:
With Ctrl-Z drive is ready with full ID and i get following Terminal-Output:
Boot 0x80M
Tech Unlock Handshake: 0xFD2BD4C0
Reply:
QB
(P) SATA Reset
RAW OFF
PASS
ProcessRWError -Read- at LBA 0006FC8C20 Sense Code=43110081
ProcessRecoveryComp-2
(MC POR Duration): 00000002F6
Intel 6G->3G
CSpd= 3Gbps
ASCII Diag mode
F3 T>
I could backup all systemfiles from both copies, so heads should be OK. Any other action (reading modules, refreshing informations in ulitity-status, ...) causes HDD freezing in BSY-State.
I tried to edit SMP-Flags in SysFile93 (uncheck all options without the first like described by ACE), but can't write it back (Not supported in FW).
I read, that sysfile-writing is only possible in ATA indirect mode, but don't know how to do this. Can anybody explain, please?
Thanks.
Best regards, Boerge
 Post subject: Re: ST1000LM035 - MC-Issue - can't write sysfile back
PostPosted: December 2nd, 2020, 14:31
Solved.
Had to refresh all Options in Utility Status ASAP after PowerOn (with 5 Power-Cycles). After this i could write Sysfile93 back in ATA indirect mode.
Drive is imaging now.
PostPosted: June 8th, 2022, 18:27
This stupid power cycle tricky saved me today. Exactly same issue.
