 Post subject: ST3000DM001 sata reset and no terminal
PostPosted: June 7th, 2022, 20:53
hello
I have ST3000DM001 drive.
power on, bsy
In terminal, "(P) sata reset" but I can't terminal access.
I tried head and pcb swap but same.
please help
thanks
 Post subject: Re: ST3000DM001 sata reset and no terminal
PostPosted: June 9th, 2022, 7:25
Did you try unlocking the pcb?
PostPosted: June 9th, 2022, 20:07
PCB number is 100687658 REV C
I need ROM patch?
PostPosted: June 11th, 2022, 6:01
What's the PN (Part Number) on the label?
PostPosted: June 11th, 2022, 8:01
100687658 is for 1CH, not locked.
PostPosted: June 12th, 2022, 19:53
PN: 1E6166-570
PostPosted: June 13th, 2022, 13:20
juhyuk wrote:
PN: 1E6166-570
I think you meant to say 1ER166-570.
I believe this drive requires ROM Unlock patch to get terminal access.
PostPosted: June 13th, 2022, 19:50
the PN is ok, but it is something rare, at least here, I never had one... Should be an old Grenada.
I should take a look at the fw to find out if it is locked, but have no time atm.
PostPosted: June 13th, 2022, 22:46
labtech wrote:
juhyuk wrote:
PN: 1E6166-570
no It's real haha..
PostPosted: June 13th, 2022, 22:49
Interesting, have not seen that one before.
Either way, if in the terminal it says "Diagnostic Port Locked", then it is a locked ROM based model.
PostPosted: June 13th, 2022, 22:50
thanks
PostPosted: June 13th, 2022, 22:52
first picture only in terminal
still bsy and can't access terminal and no more code
PostPosted: June 14th, 2022, 4:00
It shouldn't be locked.
The locked Grenadas have a 'triangular' PCB shape, this is the old classic one, to my knowledge they weren't locked.
PostPosted: June 14th, 2022, 4:02
By the way, if you leave it powered on, chances are it will eventually get to DRD DSC.
It sounds like typical Congen thing to me.
PostPosted: June 14th, 2022, 7:44
already I tried...
Is 30 minutes not enough? I waited 30 minutes but no response.
PostPosted: June 15th, 2022, 2:04
Did you try to patch ROM to pause boot after power on and then hit CTRL+Z immediately after you continue booting?
PostPosted: June 15th, 2022, 22:30
only tried CTRL+Z
T> is displayed on the terminal, but there is no response after (P)SATA reset.
PostPosted: June 18th, 2022, 9:46
Basically i would have said the same but since i haven't had time to look at the firmware, i hadn't say so coz i can't be sure. PCB shape itself does not imply anything about the firmware.
Users browsing this forum: Google [Bot] and 77 guests
