 Post subject: WD20SDRW-11VUUS0 ROM corruption
PostPosted: June 15th, 2022, 22:37
hello
I have WD20SDRW-11VUUS0 drive
This drive is no spin
I think ROM corruption.
Because it works with other PCB. (no ROM swap)
but no spin after ROM swap.
I want to analyze the ROM, but I can't read the ROM.
How to read ROM?
 Post subject: Re: WD20SDRW-11VUUS0 ROM corruption
PostPosted: June 15th, 2022, 22:38
PCB num. 2060-800067-001 REV P1
PostPosted: June 16th, 2022, 12:41
You can’t read it with a chip reader?
PostPosted: June 17th, 2022, 12:29
I tried using a socket and a pin cable, but I couldn't read it.
PostPosted: June 18th, 2022, 9:10
I often find it necessary to solder the ROM onto an adapter board which then plugs into the reader. Have you tried that?
PostPosted: June 19th, 2022, 19:54
oh thanks
I will try
PostPosted: June 25th, 2022, 12:20
Use same fw version ROM, unlocked, and solder to original PCB
Angel Data Recovery
PostPosted: June 27th, 2022, 15:02
Great to know, thanks!
