 Post subject: Data recovery for Seagate HDD 3,5" (deleted partition)
PostPosted: July 12th, 2022, 17:19
So my problem is the following:
I had a 1 TB Seagate disk with two partitions, one was for data ( ~ 629 GB ) and the other had a Windows 10 installation ( ~ 300 GB ). Then what I did was deleting the Windows 10 partition/volume and also the reserved Windows 10 volumes/partitions ( I had installed windows on another disk so I didn't need it anymore ).
After that, I had extended the data partition with disk management using the unallocated space of the old Windows 10 partition. Windows asked me to convert the disk into a dynamic one and I accepted.So I was seeing two volumes on disk management which were shown as one disk on File Explorer and they were working fine. Don't ask me why I deleted the ex-Windows 10 partition and what happened is that both partition got deleted and now I was seeing 1 TB ( 931 GB to be specific ) of unallocated space. I created a new disk without formatting and now I see an inaccessible RAW data disk.
What I want to do is recover/restore the original ~ 629 GB partition I don't care about the old Windows 10 partition. I'm trying to use DMDE but I'm not sure what to do, I can provide more screenshots if needed.
File comment: Partition found with DMDE
 Post subject: Re: Data recovery for Seagate HDD 3,5" (deleted partition)
PostPosted: July 13th, 2022, 1:56
Sir ,
What Model HDD is This exact model please ,check in some utility
PostPosted: July 13th, 2022, 3:27
It's in the screenshot ST10000DM10 so should be CMR.
Your files should be visible if you select the 676GB partition - you should be able to recover from there, I don't like in situ partition restoration.
PostPosted: July 13th, 2022, 7:17
Yes they are but I would like to restore somehow the partition, I don't have an external free drive.
PostPosted: July 13th, 2022, 7:50
Just select Disk 1 - right click - GPT off - right click 676 GB partition and select restore boot sector from copy - right click on the same partition and select insert the partition - power off and power on the drive.
Now you have full access to your deleted partition and unallocated 300GB.
PostPosted: July 13th, 2022, 8:49
Sorry ,
I missed that ,this should be recoverable .
