 Post subject: Compatible SATA PCB for WD 2060-810035-000 REV P0
PostPosted: February 15th, 2025, 18:24
I haven't been able to find info on a SATA PCB match for a WD USB PCB 2060-810035-000 REV P0. Any suggestions?
HDD Model: WD50NMZW-59BCBS1
Thanks in advance.
 Post subject: Re: Compatible SATA PCB for WD 2060-810035-000 REV P0
PostPosted: February 16th, 2025, 20:18
Depends what your trying to do and what tools you have. There is no magic pcb swap for this model. You can convert the pcb to sata yourself.
Zero Alpha: zeroalpha.com.au
PostPosted: February 18th, 2025, 14:05
Hi Zero, I'm using a Deepspar and I don't have the USB module for it. I was hoping there was a compatible SATA PCB so I could do the usual ROM swap and be good to go.
PostPosted: February 18th, 2025, 15:47
Shure, if there is one but you need to move MCU too, as those drives are encrypted. Never tried to find any SATA for those. It's easier to convert USB to SATA.
odzyskiwanie danych
PostPosted: February 20th, 2025, 10:48
Is there any proper guide for that?
PostPosted: February 20th, 2025, 15:45
https://blog.acelab.eu.com/pc-3000-hdd- ... drive.html
odzyskiwanie danych
PostPosted: February 25th, 2025, 4:23
melvin wrote:
https://blog.acelab.eu.com/pc-3000-hdd-how-to-solder-a-sata-adapter-to-the-usb-western-digital-drive.html
Thanks is there any guide specific for board 800067 ?
PostPosted: February 25th, 2025, 7:23
They all are made the same way. Unsolder 4 capacitors from USB bridge and solder SATA. That's all.
odzyskiwanie danych
PostPosted: February 25th, 2025, 7:29
If this is a clients data, you should outsource and not risk making things worse.
PostPosted: February 25th, 2025, 16:26
You could try a "probe board":
https://www.youtube.com/embed/iO3tlg1_kyg
This trick might also help to improve your results with the probe board:
Locating the Reset* pin on USB-SATA bridge ICs:
https://www.hddoracle.com/viewtopic.php?f=59&t=3381
PostPosted: February 26th, 2025, 9:03
Thanks in advance.
810030
PostPosted: February 26th, 2025, 20:20
Thanks, very helpful.
Users browsing this forum: Majestic-12 [Bot], skinbob and 67 guests
