 Post subject: Hd 3 Err Blk
PostPosted: June 27th, 2022, 6:15
ST2000LM007-1R8174 SBK2
What is Wrong here ??
Reading starting sectors approx 20GB OK , And Most are showing Bad.
EDAC Value = 0000000018147566
Starting LBA of RW Request=0018149FD1  Length=00000A68
ProcessRWError -Read-   at LBA 001814A0C9  Sense Code=44090082
Common path start quit now ProcessRC: 00000001,00000000SkipLen: 00000000ReadContinuous: 1814A0AF,000001BCUnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000,00000000Passed: 00000080,000000B1,0000018FOut:  OfflineOC
ERROR
SP Regen FAIL
SPRegen [0000|400000A6] @LBA=0x1814A0C9
Setup currentretry count
Hd 1  Err Blk     1814A0C9  BER pre -1.932958
Out:
Update Mask - 00000000C0A50648 - 00000008 - 00
Harden - 1814A0C9
InitiateMarkPendingReallocateRequest for disc_lba: 001814A0C9 CHS: 0004F323.01.001A
Assert 741D - LBA 1814A0C9!
EDAC Value = 0000000018147567
ProcessRWError -Read-   at LBA 001814A0CA  Sense Code=44090082
ERROR
SP Regen FAIL
SPRegen [0000|400000A6] @LBA=0x1814A0CA
Hd 1  Err Blk     1814A0CA  BER pre -1.934795
Out:
Update Mask - 00000000C0A50650 - 00000008 - 00
Harden - 1814A0CA
InitiateMarkPendingReallocateRequest for disc_lba: 001814A0CA CHS: 0004F323.01.001B
Assert 741D - LBA 1814A0CA!
 Post subject: Re: Hd 3 Err Blk
PostPosted: June 29th, 2022, 7:32
You have head problems at the minimum. These drives crash very easily and it's probably fast on it's way downhill. I would advise against running this any more before getting it to a data pro. Have to be careful with head swaps as only some replacements will be able to write to the system area well, others will try on power up and corrupt the SA losing unique translator data etc.
PostPosted: July 8th, 2022, 3:58
Actually , The Issue Resolved . I did translator Regenerator with writing original sys 28 35 back.
I got the Data 100%
PostPosted: September 23rd, 2022, 21:29
Whats the purpose of writing back your sys 28 35 ?
Users browsing this forum: Majestic-12 [Bot] and 48 guests
