Post new topic Reply to topic  [ 88 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: ST3000DM001 1CH166-510 issue
PostPosted: September 13th, 2022, 5:55
Hello everyone :)
Sorry about the random order of information here, I just wrote it as it entered my head. I'll add to this as I think of more.
Unknown FW version atm, sticker says CC27 but I likely updated it if there was ever a update available.
Drive is from a media PC running 24/7. Hardware and software of said PC has been upgraded multiple times over the years.
First identified the actual drive being faulty at the very start of this month.
I was listening to music on the media PC, and it had long pauses after starting a new track, then it just disappeared.
It was doing this for an unknown amount of time when listening to music on another PC in my network, but I assumed it was something unrelated. The pauses were much shorter so I assumed it was buffering on my PC or network buffering or something like that.
I believe this was bought in Jul 2015.
I've read through all 127 threads with this model in the title and learned what I can, but I'd like some opinions on what to do next please.
I cannot afford a professional recovery service, but If worse comes to worse I'll wait until I can. Might never be affordable though for reasons I'm not going to go into here.
I bought a usb to ttl adapter but I'm yet to try that approach. - https://www.ebay.com.au/itm/302329541628
I managed to get the drive to show when connected to an external usb dock and it only showed on my older laptop not my media PC.
I managed to copy just under 8GB of data before It threw errors in teracopy, after that I could still "see" the drive, but couldn't open any files.
This is when I stopped trying to do anything with it and haven't plugged it back in since.
This is the USB dock I'm using - https://www.vantecusa.com/products_detail.php?p_id=184
Dock works fine with another HDD when connected to the media PC.
Stopped showing in bios when connected to internal sata connecter on the motherboard. Didn't show in the external usb dock either.
When trying to use the ST3000DM001 with the dock connected to the media PC the device manager said "The USB set address request failed."
I assume (and you know what they say about assumptions) that the UEFI bios might be the main difference with the success of actually reading the drive on the laptop (laptop is from 2010 so no EUFI bios) Probably just something related to the chipsets or something like that though.
Drive spins up and sounds normal.
I'm in Tasmania, Australia if anyone knows any reputable DR places if it comes down to that.
I've already bought a new drive.
Was only using between 693GB to 1TB max space on the drive. I don't have an exact number, but the 693GB is the last known space used. And I think it was only about 50GB more than that at most, but saying 1TB to be safe.
Is there any safe diagnostics I can do to get as much info as possible to share here?
Thanks in advance for reading, and I look forward to any and all suggestions and advice :)
P.S. Sorry for the wall of text.
 Post subject: Re: ST3000DM001 1CH166-510 issue
PostPosted: September 14th, 2022, 3:25
I think it's time to try that approach.
Of course, your best bet would be to trust a reputable DR lab.
If the drive is not clicking and stays spinning up as you say, most probably it shouldn't be that expensive at this point.
PostPosted: September 14th, 2022, 5:21
I don't fully understand how to take that approach, as the only detailed guide is for the 7200.11 series. I need to know if it is at all a viable approach I guess.
I'll await some more replies before doing anything though. Thank you for your response :)
PostPosted: September 14th, 2022, 17:55
Connect the terminal and post the power up log here. Don't issue any commands.
PostPosted: September 14th, 2022, 20:23
I assume I still connect the HDD to sata power but not data?
PostPosted: September 15th, 2022, 8:13
it doesn't matter if you connect the sata cable or not, grab the log on the terminal when power is applied to the drive.
Perhaps using an external PSU.
PostPosted: September 15th, 2022, 22:33
Okay, I'll give it a try and report back.
PostPosted: October 4th, 2022, 23:26
These are the results I got. I wasn't sure about the TX and RX orientation but I'm assuming that the second result is the correct orientation?
Spin ▒p~▒Tr▒▒▒)▒▒▒
(P) SATA Reset
SWAPPED RX AND TX HERE and rebooted etc.
C!▒닁0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0015
(P) SATA Reset
CTRL + Z worked here but this is where I stopped.
Please tell me how to progress? Thanks :)
PostPosted: October 13th, 2022, 10:33
Can anyone please help?
PostPosted: October 13th, 2022, 10:59
Power down the drive
Power up the drive
Then crtl-z
Then ctrl-x
Post the output here.
PostPosted: October 13th, 2022, 12:10
Ok, I'm about to go to bed so I'll do it when I get up in the morning.
Should I do a SMART command too?
PostPosted: October 14th, 2022, 4:26
Just a small update, I couldn't get my adapter working today for some reason, and had no time to troubleshoot, I'm going to try again sometime over the weekend and report back.
PostPosted: October 15th, 2022, 5:53
As far as I can tell I've broken my adapter, so I'm going to buy another one in a couple of weeks and then likely start a new thread for visibility.
PostPosted: October 15th, 2022, 10:40
how did you manage that ? :)
are you sure it is broken? test it by shorting tx and rx pins, you should get chars you type in a terminal prog echoed...
PostPosted: October 15th, 2022, 12:54
I'm not sure, but I cannot get it to show anything when it's connected to the drive, or If I short the cables out.
I'll try it again before buying a new one, but I've got no idea what's happened.
The light turns on when it's connected or shorted, so It's clearly completely the loop.
I tried it with another PC and same thing.
PostPosted: October 25th, 2022, 22:49
Small update. I've got a new adapter on the way.
PostPosted: December 3rd, 2022, 5:33
Power up the drive
Then crtl-z
Then ctrl-x
Sorry to @ you both, but it has been so long and I wasn't sure anyone would see this otherwise.
Finally had time to work on this again.
I used the CTRL+X command 3 times just because there seemed to be some inconsistency each time.
Boot 0x40M
Spin Up▒Ʌ▒͹
Spin Up
SpinOK
TCC:001D
(P) SATA Reset
ASCII Diag mode
F3 T>
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
      9166 99999999        7 02  011201 000000 1 00000080 XFR R▒ SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.05FFFFF.0&(▒▒j
        9199                 33        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
      9206        7        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
      9215        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
      9223        8        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009D917 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
      9231        8       10 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES▒0068D27.0068F26.0068D27
      9241       10        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      9249        8        0 27  028201 000000 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000
        0000 0000 0000 0000 0000 0000 0000 0000
    ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒j
        0001 D719 00D0
        674C 0001 0000 0001 0004 EC40 11E0 DE74
        0003 0F9F 0F8D 0F78 0F71 0F80 1000 1053
        FE7B 5B07 BB14 53E2 49CC 9AD1 46▒A 7B63
        AAF0 6F13 7B7E CFC9 3D1A E4E2 5551 1229
      9250        1        6 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003FDBB L 000000000001 BO 000000 BES 0068487.00684C6.0068487
      9256        6        5 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000421AF L 000000000003 BO 000000 BES 00684C7.0068586.00684C7
      9261        5        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      9277       16      113 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003C5BB L 000000003800 BO 000000 BES 0068F67.0148F66.0068F67
      9597      320        9 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
      9606        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
      9614        8        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009D933 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
      9623        9        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
      9649       26        7 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF3 L 000000000001 BO 000000 BES 00689E7.0068A26.00689E7
      9656        7        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D280.022D37F.022D280
      9664        8        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
      9672        8        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
      9681        9       10 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000003DB094 L 000000000001 BO 000000 BES 0241A80.0241ABF.0241A80
      9697       16       59 02  011101 000000 1 00000080 XFR RD USR LBA B 00000000255A L 000000000762 BO 24000E74 VL E89C.3B10
      9757       60       38 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      9795       38       16 02  028201 000000 1 00000080 XFR▒WR SYS LBA B 00000009EDDA L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      9812       17        4 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      9816        4        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      9827       11       27 02  011101 000000 1 00000080 XFR RD USR LBA B 000000000000 L 0000000001A8 BO 24000E74 VL 2C9C.0D40
      9950      123       12 02  028101 000000 1 00000080 XFR WR USR LBA B 000000000000 L 0000000001A8 BO 24000E74 VL 3C9C.0D40
      9962       12       20 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
      9982       20        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650D▒
      9990        8        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
     10000       10  ▒▒▒▒▒�▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒�▒I▒WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
ASCII Diag mode
F3 T>
ATA  15 Cmds
         0▒       0 00 0000 000000000000
         0        0 00 0000 00000000000j
    ▒    0        0 00 0000 000000000000
RW  32 Cmds
      9166 99999999        7 02 ▒011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.05FFFFF.03BF800
      9199       33        7 02 ▒011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
      9206        7        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 ▒
        ▒▒▒▒▒▒M▒022D280.022D2BF.022D280
      9231        8       10 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      9249        8  ▒▒▒▒▒�▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒�▒9}MIY▒0C01 0000 0000 0000 0000 0000 0000 0000
        0001 D719 00D0
        FE7B 5B07 BB14 53E2 49CC 9AD1 46AA 7B▒j
        ▒            AAF0 6F13 7B7E CFC9 3D1A E4E2 5551 1229
▒    9250        1        6 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003FDBB L 000000000001 BO 000000 BES 0068487.00684C6.0068487
      9614        8        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009D933 L 000000000002 ▒O 000000 BES 022D280.022D2FF.022D280
      9672        8        9▒02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
      9795       38       16 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009EDDA L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      9812       17        4 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 00000000000=▒000000 BES 0068D27.0068F26.0068D27
      9962       12       20 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373|5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
      9982       20        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
     10000       10        8 02  028201 000000 1 00000080 XFR WR SYS L▒A B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
ASCII Diag mode
F3 T>
ATA▒ 15 Cmds
         0        0▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒j
RW  32 Cmds
      9166 99999999        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.05FFFFF.03BF800
             ▒▒▒▒"▒19 00D0
        ▒ 674C 0001 0000 0001 0004 EC40 11E0 DE74
        ▒                                                         FE7B 5B07 BB14 53E2 49CC 9AD1 46AA 7B63
      9277       16      113 02  011201 000000 1 00000080 XFR RD SYS▒LBA B 00000003C5BB L 000000003800 BO 000000 BES 0068F67.0148F66.0068F67
      9656        7        8 0>  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D280.022D37F.022D280
     10000       10        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
ASCII Diag mode
F3 T>
ATA  15 Cmds
         0        0 ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒j
RW  32 Cmds
      9231        8       10 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068|27
      9249      ▒ 8        0 27  028201 000000 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000
        0001 D719 00D0
      9250        1        6 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003FDBB L 000000000001 BO 000000 BES 0068487.00684C6.0068<87
      9256        6        5 02  011201 000000 1 00000080 XFR RD SYS LBA▒0000000421AF L 000000000003 BO 000000 BES 00684C7.0068586.00684C7
      9990        8        9 02  028201 000000 1 00000080 XFR WR SYS L▒A B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
PostPosted: December 3rd, 2022, 6:21
there are lot of bit errors in the serial communication, which might be due to wrong IO voltage or bad/missing grounding?
PostPosted: December 3rd, 2022, 6:40
I wasn't aware it needed grounding, I only had RX and TX connected.
Assuming I just need to use the ground pin on both the HDD and adapter?
PostPosted: December 3rd, 2022, 6:55
Yes, of course, need to connect gnd.
