 Post subject: Re: toshiba rom extract
PostPosted: September 13th, 2022, 22:49
I have attached your CPs.
CPs_01.7z [11.55 KiB]
Downloaded 429 times
PostPosted: September 13th, 2022, 23:07
The CPs appear to be OK, but I don't know how to validate the checksum/CRC of the code section of the ROM. The safest approach would be to find a matching donor ROM (FW version AVF01M0B), and then patch the code section (0 - 0x77BFF) into the patient ROM.
I think it should also be OK to find any donor ROM from the same model and do the same patch. That's assuming that there are no other code overlays in the SA, and that all code is ROM resident. If you can find a suitable donor, I can do this for you.
00022400  54 4F 53 48 49 42 41 20 4D 51 30 31 41 43 46 30  TOSHIBA MQ01ACF0
00022410  35 30 00 20 20 20 20 20 20 20 20 20 20 20 20 20  50.
00022420  20 20 20 20 20 20 20 20 20 20 55 53 45 52 20 46            USER F
00022430  57 20 56 45 52 53 49 4F 4E 20 20 41 56 46 30 31  W VERSION  AVF01
00022440  4D 20 20 00 20 20 46 41 43 54 4F 52 59 20 56 45  M  .  FACTORY VE
00022450  52 53 49 4F 4E 20 20 41 56 46 30 31 4D 30 42 00  RSION  AVF01M0B.
00022460  30 31 2F 32 34 2F 32 30 31 34 00 00 FF FF FF     01/24/2014..ÿÿÿ
PostPosted: March 18th, 2026, 1:56
where i can find Toshiba rom CP extract? those from hddoracle not open under Windows 10-11...
Thanks!
PostPosted: March 18th, 2026, 12:41
Those are command-line tools.
PostPosted: March 18th, 2026, 13:22
sorry, hard to play with it, thought that are more easier
PostPosted: March 18th, 2026, 13:34
Upload your ROM and I'll extract the CPs for you.
PostPosted: March 20th, 2026, 10:37
Sorry, i wanted to search a way to full unlock the VS series and i find it at the end
Thanks!
PostPosted: March 20th, 2026, 10:58
you have it attached
File comment: here is it ( change .rar with .bin )
2VC2T0E1QCZ.rar [512 KiB]
Downloaded 215 times
PostPosted: March 20th, 2026, 12:16
Attached.
CPs_00.7z [11.16 KiB]
Downloaded 198 times
PostPosted: March 20th, 2026, 13:27
are you able to help me how to run that app to can work on my solution? even maybe to improve some stuff, wanted to send mesage but no contact :D
PostPosted: March 20th, 2026, 13:38
My "app" works fine in a Win 10 CMD window.
tosromcp9.7z [27.43 KiB]
Downloaded 311 times
PostPosted: March 20th, 2026, 14:33
ok, then i need to find right comands for running maybe
PostPosted: March 20th, 2026, 14:35
you can find me on telegram @GabrielDRro
PostPosted: March 20th, 2026, 14:38
Do you understand what a command line is? CMD?
PostPosted: March 21st, 2026, 1:35
i will try to find how to run it with CMD
PostPosted: March 21st, 2026, 1:40
OMG, really? it works if i drag the ROM over the Exe. i made a good mistake
Thanks!
PostPosted: March 21st, 2026, 11:22
https://www.geeksforgeeks.org/techtips/windows-command-prompt-tutorial/
https://www.geeksforgeeks.org/techtips/most-useful-cmd-commands-in-windows/
Users browsing this forum: Majestic-12 [Bot] and 77 guests
