 Post subject: Very strange problem with WD40EDAZ 4TB
PostPosted: September 15th, 2022, 11:01
Hello everybody, I am having a problem with this WD40EDAZ that is driving me crazy.
I am using unlocked ROM now. HDD spins up and gets ready with full ID but, as soon as it gets ready, it reboots immediately (like power off / on) and continues in this way forever.
I tried to block SA access, the HDD keeps spinning and doesn't reboot. With SA blocked, I have full SA access (I made a full backup) and made heads test with success. But when I allow SA access in RAM and click "soft reset" to make HDD work, it makes power cycle and reboot. So I can't read anything from it.
I already tried to swap PCB, it's the same. Do you have any hint for this? Heads seems to work and I have full SA access but hdd always reboots as soon as it gets full ID. I also tried blocking 02 module and hdd works and has full SA access but then it has same problem.
Simone
 Post subject: Re: Very strange problem with WD40EDAZ 4TB
PostPosted: September 15th, 2022, 11:49
190 Module got corrupted (affected with garbage). Thats common for VeniceRs. Could be solved. Don't do heads swap, it won't help.
Angel Data Recovery
Users browsing this forum: Google [Bot] and 84 guests
