 Post subject: Shorted HDD - Will removing TVS Diode Help?
PostPosted: October 10th, 2022, 15:52
I'm pretty sure I shorted my HDD's - they are HGST 6TB SAS drives (HUS726060ALS640).
Reading through the forum, it looks like the drives might be salvaged if I pull the 5v and/or 12v TVS Diode?
The drives don't power at all when connected directly to a SAS/power cable.
I'm assuming the parts on the board I've marked are the diodes?
Is there anything else I should check?
Any help would be really appreciated!
 Post subject: Re: Shorted HDD - Will removing TVS Diode Help?
PostPosted: October 11th, 2022, 9:01
Try check fuse resistors or 0R resistors.
PostPosted: October 11th, 2022, 12:14
Check the fuses as well.
Users browsing this forum: Google [Bot] and 26 guests
