 Post subject: SCO Unix data recovery, HDD with bad blocks
PostPosted: October 27th, 2022, 18:47
I was able to image the 20GB HDD that should have around 18GB of data, it had lots of bad blocks in the front area but using PC3K I can only see around 2GB of data.
The data is coming from SCO Unix server (version 5).
I also tried to see the data using UFS, Kernel for SCO open server, and RStudio without success.
What you have used to read data from SCO Unix devices?
 Post subject: Re: SCO Unix data recovery, HDD with bad blocks
PostPosted: October 28th, 2022, 2:56
Concentrate your efforts to read better areas with bad blocks.
Angel Data Recovery
Users browsing this forum: Google [Bot] and 80 guests
